Throttle body CFM?
Old Jul 19, 2010 | 04:08 PM
Bow-Tie-Beast's Avatar
Default Throttle body CFM?
I am wondering if I could find out the CFM of my air intake to the throttle. I know it would go up as the engine revs higher but how much? Is there a tool or device that I could get my hands on to find this info?
Thanx to anyone who can share some info.
OH, my info is in my sig.
Old Jul 21, 2010 | 10:26 AM
Gordy M's Avatar
A high quality scan tool/software will tell you how much you are flowing. Years ago I remember the Corvette engineers saying the 2002 Z06 would flow just under 750 cfm and they were only using about 605 cfm. to make 405 hp.
Old Jul 22, 2010 | 07:14 PM
Have any ideas of what the scan tool would be called or where to find something like that? Thers got to be somthing out there for measuring air flow to a throttle body.
Old Jul 22, 2010 | 07:53 PM
Atomic's Avatar
I have a gauge for that
hmmm, well you could measure mass air flow and convert that from pounds/min to cubic feet per minute based on the density of the air. Except density depends on many things, but mainly temperature where this will be useful:
Code:
Temp (F)  Density(slug/ft^3)e^-3 Specific Weight(lb/ft^3)e^-2
0	2.683 	 8.633
10	2.626 	 8.449
20	2.571 	 8.273
30	2.519 	 8.104
40	2.469 	 7.942
50	2.420   7.786
60	2.373 	7.636
70	2.329 	7.492
80	2.286   7.353
90	2.244   7.219
100	2.204 	7.090
120	2.128 	 6.846
140	2.057 	 6.617
This is assuming that 100% of the air passing through the MAF enters the engine, which I think its pretty reasonable.
Lets say the MAF shows 25 lb/min and its 80 degrees outside, the formula would be something like
(25/0.07353) = 340CFM
Looking at one of my old HPtuners logs when I still had the MAF attached, I maxed it out at 512 grams/second which is 67.7 pounds/minute. Using the table from above that is roughly 925CFM. Using data from the performance maps of the tvs1900 and with my boost level and RPM it should flow around 1000CFM. So its around a 7% error, which isnt too bad of a guess considering it was maxed out.
natejk
Nov 15, 2016 08:05 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
OHsixLS3
Sep 25, 2015 11:20 AM
99bluefirebird
Sep 17, 2015 08:05 PM
