Thread Size
Old Jun 4, 2010 | 08:01 PM
o2man98's Avatar
Default Thread Size
What size are the threads of the cooler lines going into the radiator? I need to extend the lines out about 1.5" to get e-fans in and thought about adding a metal piece instead of splicing in rubber hose.
Old Jun 4, 2010 | 08:09 PM
Jordan927's Avatar
5/8-18 inverted flare
Old Jun 4, 2010 | 08:33 PM
budhayes3's Avatar
PT's Slowest Truck
Curious as to why you need to extend the trans lines for efans, why and what kind of fans are you going to use?
Old Jun 4, 2010 | 10:03 PM
o2man98's Avatar
Thanks Buddy!!!
I have a set of 08-09 Tahoe fans that I am putting on the H2. The oil lines pass about 3" from where the front edge of the fan will be. The lines cross the radiator diagonally. The e-fan is about 4" deep at that area.
Old Jun 4, 2010 | 10:09 PM
budhayes3's Avatar
PT's Slowest Truck
Ahhh, gotcha
Old Jun 5, 2010 | 10:31 AM
SnakeOiler's Avatar
There is a line bracket that should attach to the shroud to hold those lines. Do the newer fan shrouds not have that provision?
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Superman09
Sep 25, 2015 05:55 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
