those who did their own posi install
is this website accurate for the steps to install posi?
http://www.gnttype.org/techarea/suspension/posi.html
Seems pretty accurate, I just did this 2 weeks ago and took a load of pics and am going to be putting a little article together using the eaton instructions that Eaton sent with it. There were a couple things that I didn't have that cost me some time, like a greaker bar to get the rear brakes off and a vice to hold the eaton to tighten the ring gear on to the specs. Also need a torque wrench that goes to 150 ft-lbs for the rear brake brackets.
Let me know if you have any questions, I should have that write-up by the first. Here is a link to the eaton instructions.
http://james.jaguar.net/agreif/eaton...structions.doc
Andrew
Andrew
mz00516
Aug 23, 2015 12:19 PM
