Thorley vs OBX
Old Oct 19, 2008 | 07:42 PM
  #31
outlawz2004's Avatar
Originally Posted by 02SilveradoLT
To a certain extent. A gas engine does need some backpressure.
Nope. Doesnt need any backpressure. It needs velocity. The backpressure myth has been spread for years, often by exhaust shops confussing it with velocity. Often times a little backpressure can help the velocity of the flow and this causes the confusion.
Old Oct 19, 2008 | 08:01 PM
  #32
LMSeven's Avatar
Originally Posted by GMCtrk
hmm, that sucks. I think a good coating on the Pacesetters will cost at least $250. That puts you in the $700-800 range....might want to look into a used set of Dynatech's for that price.
You can get painted Pacesetters for $250, $130 for the Y pipe. Jet Hot for $250~ =$630~
Old Oct 19, 2008 | 08:30 PM
  #33
02SilveradoLT's Avatar
Pacesetters with jet hot coating kinda put me into a different price range... Maybe I should just go with the thorleys...
Old Oct 19, 2008 | 11:23 PM
  #34
fastgmc53's Avatar
14 Second Truck Club
Pacesetters also come ceramic coated for 350ish. That is what Jet-Hot will do for $250. just order them coated and your good to go. The ceramic coating wont rust or turn blue as long as you clean them every year or so with the special polish you can find online.
Old Oct 19, 2008 | 11:46 PM
  #35
TX Tahoe Z71's Avatar
People seem to say that the factory applied coatings don't last but a couple of years, even less near the coast and where the roads are salted. Jet Hot's coatings usually last for much, much longer. It does cost more, but if it doubles the life of your headers, I say it's worth it. My painted JBA's on my Bronco only lasted 3 years before some of the welds rusted through... wish I had them coated when I bought them, that was $500 not well spent.
Old Oct 20, 2008 | 12:51 AM
  #36
SlvrSierra4.8's Avatar
You can pick up a set of coated Thorley's for about $525. Too bad they don't offer a y-pipe tho.....
Old Oct 20, 2008 | 12:23 PM
  #37
I'm thinking Thorleys now once again. It's just kind of hard to justify getting the Pacesetters then sending them in to be coated, and the total price would put me at or most likely above what the thorleys cost. But yeah that Y-pipe thing, I dont see why the Pacesetter Y-pipe wouldnt work. And probably send the Y to Jethot to be coated.....
Old Oct 20, 2008 | 01:29 PM
  #38
LMSeven's Avatar
Because the Pacesetters have 3" collectors, Thorley's don't, I think they have 2.5" collectors.
Old Oct 20, 2008 | 01:45 PM
  #39
GMCtrk's Avatar
2.5" isn't going to make any difference on a stock 5.3. That's why I no longer have any reservations getting the OBX's. I was told it would only make a difference if I was pushing big power...
Old Oct 20, 2008 | 02:31 PM
  #40
KevinF56's Avatar
yep. my pacesetters are rusting pretty bad, especially on the collectors, after 2 winters. and yes, they are the coated version.
