thinking of going true duals
Old Oct 19, 2014 | 07:08 AM
1lowgmc's Avatar
Default thinking of going true duals
I have a nnbs 4.8, with lt's,no cats, dynoed at just under 350rwhp, with heavy 22's. I currently run a 3" y-pipe, into a super 44. While it does sound good at times, I could use a little quieter set up. I am thinking of going true 3" duals with an x-pipe, and 20" magnaflows. Is the 3" overkill or would like 2.5" be better. I do plan on a few more na mods to get me too the 400hp mark.
Old Oct 19, 2014 | 09:51 AM
musclecity85's Avatar
if your just looking for a quieter setup you could just swap muffles. i went from a flowmaster 50 series to a magnaflow and it toned it down alot. no more drone on the in the cab, but a nice deep sound outside. and i think a single 3' exhaust is rated to like 450-500 hp, so you should be good with that. Im sure true duals with an x pipe will have a different sound, but sound good at the same time
also whats your setup? cause 350rwhp from a 4.8, im sure your truck rolls out
Old Oct 19, 2014 | 09:58 AM
03sierraslt's Avatar
We need to know the whole setup, because a 4.8 with headers and exhaust isnt 350hp. But yes, dual 3" is overkill.
Old Oct 19, 2014 | 03:02 PM
black00chev's Avatar
Slowest turbo build ever!
Stay with a single 3" or do dual 2.5".
But im a simple man and say keep it simple with just a single 3" with a bigger muffler.
Old Oct 19, 2014 | 04:33 PM
1lowgmc's Avatar
I have a custom cam, lsxrt, double springs, pushrods, CAI, built trans, 3200 stall, 2 piece driveshaft, 4.11 gears w/truetrac, probably more hard to keep track sometimes. I was thinking a true dual with xpipe may gain some low end, from my research. But trucks are much heavier. Thanks
Old Oct 19, 2014 | 04:55 PM
So the 350hp is a estimate.
Old Oct 19, 2014 | 05:12 PM
1lowgmc's Avatar
No it was dyno'ed by PCM of NC when the can was installed.
Old Oct 19, 2014 | 10:49 PM
JohnDaMan's Avatar
Is this your truck?
Why not ask Alvin?
Old Oct 19, 2014 | 11:34 PM
danny23's Avatar
I agree i will.like to.know.your set up it will be nice to get the much hp with just LTs,,, im running lts x pipe with 3" pipe and stock cats and e-fans ls6 intake ported tb and a tr220 and maybe im putting like 300-330 rwhp maybe not sure
Old Oct 19, 2014 | 11:38 PM
danny23's Avatar
what are the spects for ur custom cam u have some nice number for a 4.8 with a cam,, nice bro
