View Poll Results: Which combo
LQ4 with PRC 2.5 862s (58cc) = 11.0 CR
17
80.95%
LQ9 stock heads.
19.05%
Voters: 21. You may not vote on this poll
thinking about picking up a 6L, need some opinions..
Old Apr 8, 2010 | 12:40 PM
BlackGMC's Avatar
Resident Retard
Ok, here are some numbers of cam specs i threw together... I am trying to keep the DCr around 8.5ish....
option #1
LQ4 with my 58cc PRC heads, stock head gasket (.052)
224/224 .581/.581 114+2
CR = 11.01
DCR = 8.53
overlap -4*
Option #2
226/226 .585/.585 114+3
CR = 11.01
DCR = 8.50
overlap -2*
Either one of those should be pump gas friendly, have good midrange and idle stable... Option 1 might have a little more lowend and less topend than option 2 given the change in overlap...
now i could throw in a set of cometic .060 head gaskets to drop the compression down some, then i could increase the ICL a tad to compensate, which might allow me to run a little more timing and be even more pump gas friendly....
Old Apr 8, 2010 | 12:41 PM
fastrt's Avatar
11 Second Truck Club
Originally Posted by BlackGMC
yep lots of practicing going on
LMFAO!!!!
I vote 06 and newer lq4 with your tsp heads. you get beefier rods with the newer motors right? where are you looking? I would replace the rod bearings, and put arp rod bolts in just as a piece of mind/don't have to mess with it later on a used motor. either way will be fun!
Old Apr 8, 2010 | 12:43 PM
BlackGMC's Avatar
Resident Retard
Yeah and to think I breathed a sigh of relief when he said he might not have kids
Well i am not throwing kids out of the equation, lets just say the safety measures normally in place to prevent them have been taken out of the equation.... so what happens..... happens
I think youre on the right track Corey, I bet with your super tuning skills you could get 364 cubes down the quarter pretty quick and probably even get better mileage that the 4.8
I dunno about super tuning skills... I can cobble some **** together and yep i think if i keep it a mild build my MPG should improve...
Now what my current torque converter is going to do when i add ~80 ft/lbs tq is anyones question.... i am saving up for a Performabuilt L2 and Circle D 3c
Old Apr 8, 2010 | 12:45 PM
BlackGMC's Avatar
Resident Retard
I like the idea of the newer motor, but given how david's truck runs it may not be necessary, about cracking the motor open, that is a negative... I don't plan on spinning this one to 7k+ like the 4.8....
Old Apr 8, 2010 | 12:48 PM
fastrt's Avatar
gotcha, you going to buy a running motor then? I like the 224/114+2 and leave it at 11.01:1. stock .054 head gaskets. should be a off the like torque monster. and back the verter down to a 3000-3200?
Old Apr 8, 2010 | 12:50 PM
BlackGMC's Avatar
Resident Retard
yep i have been thinking about downgrading to a circle D worked TB converter... I am just sick and tired of idling issues... I want something i can tune once and forget it....
Old Apr 8, 2010 | 12:51 PM
00ChevyScott's Avatar
Wearin' da big hat
If I've ever seen a thread get completely and literally cluster fucked, this is it.
Old Apr 8, 2010 | 12:52 PM
BlackGMC's Avatar
Resident Retard
why is that?
Old Apr 8, 2010 | 12:55 PM
fastrt's Avatar
thats cool, and still make 400hp. you are wanting to change right when I am planing a head/cam swap lol. oh well I am always playing catch up anyways
Old Apr 8, 2010 | 12:56 PM
BlackGMC's Avatar
Resident Retard
catchup? it appears that i am slow man on the pole now... well except for brendan...
mainly i am just wanting a project... Katie leaves for a month this summer so i need something to mess with...
