Is there a trick to removing the stock plug wires?
Old Feb 25, 2007 | 08:16 PM
Frito Bandito's Avatar
Default Is there a trick to removing the stock plug wires?
That little bastard didn't want to come off! I only tried one and didn't get real mean with it for fear of destroying the wire, though. Is there some sort of special voodoo dance that needs to be performed to remove GenIII plug wires? I was thinking of using some pliers on the heat shields. I'll show those little turds who's boss next weekend when I install LTs and I'll definitely use some dielectric grease when I put in new plugs.
Old Feb 25, 2007 | 08:21 PM
Derek @ EDO's Avatar
FormerVendor
pull harder lol, no special tricks required.
Old Feb 25, 2007 | 08:35 PM
RoosterMcCandles's Avatar
Just yank the damn thing...
Old Feb 25, 2007 | 08:37 PM
dkubricht's Avatar
Old Feb 25, 2007 | 08:40 PM
cyazo6's Avatar
The best thing I can suggest is to twist the plug wire boot back and fourth and it will help free it up a little bit.
Old Feb 25, 2007 | 08:48 PM
99Silverado5.3's Avatar
yeah wiggle them a little while pulling.
Old Feb 25, 2007 | 09:09 PM
First you ******* make me paranoid with your stories about destroying stock wires taking them off then you tell me to pull harder to remove them. Bastards.
In case you couldn't tell this was a joke.
Old Feb 25, 2007 | 09:35 PM
budhayes3's Avatar
PT's Slowest Truck
Twist, twist, twist...sideways (clockwise and counter-clockwise on the plug, w/o pulling). Once they break loose, they should pull off without breaking...hopefully.
Old Feb 25, 2007 | 10:51 PM
03chevy5.3rcsb's Avatar
just yank em, if you break it it'll give you an excuse to go buy some fancy lookin ones
Old Feb 26, 2007 | 12:15 AM
TXsilverado's Avatar
something in the grease the factory uses turns to concrete...serously! i fucked up all 8 factory wires because they wouldnt come loose. my new wires pop loose with minimal effort.
