There is something wrong
Old Feb 5, 2009 | 09:54 PM
07 z71 silverado's Avatar
11 Second Club
Default There is something wrong
ok well you have probably read my other threads about my fuel problems well they are still there. i just installed a walbro kit from magnacharger i think it came with a walbro 320 and i installed it perfectly and it cranked right up and normal driving is fine but wot just goes so lean i souldnt be leaning out with this pump wat do yall think is my problem bad pcm?
Old Feb 5, 2009 | 10:00 PM
viciousknid's Avatar
Where's the Beef?
Could be the same thing that Mangled03GMC was having problems with for a long time. Turns out the Sock on the pump was collapsing and choking the pump.
https://www.performancetrucks.net/fo...=fuel+problems
Old Feb 5, 2009 | 10:10 PM
11 Second Club
nah i dont think its that this sock it came with has a internal skeletan so it wont. its doing the same thing with this pump as the stock pump the pressure is at about 57 at idle but when i go wot it drops to like 50 and i know its not a bad pump because i just put a brand new stock pump in 1 month ago and just put that walbro in 1 hour ago.
Old Feb 5, 2009 | 11:13 PM
GMCtrk's Avatar
side note, how do you like your vig 3200, it's the 9.5" triple disk im assuming?
Old Feb 6, 2009 | 04:23 AM
sonoma43's Avatar
what injectors are you running?
Old Feb 6, 2009 | 07:15 AM
11 Second Club
it's a single disk 9.5" i wish i would have went bigger but i love it.
stock
Old Feb 6, 2009 | 07:40 AM
nonnieselman's Avatar
Whats the IDC?
Old Feb 6, 2009 | 08:11 AM
KLUG'S SS's Avatar
FormerVendor
Did you do your WOT tuning with a wideband?
Old Feb 6, 2009 | 03:16 PM
sonoma43's Avatar
im thinking it's a tuning issue....
Old Feb 6, 2009 | 07:09 PM
11 Second Club
the idc will reach into the 120+. i think its the computer or something i dont think its in the tune. i can add more fuel up top but when i do it just increases the idc.
