<TECH ONLY> Proven Peformance Packages! Forced induction GM
Old Dec 2, 2006 | 12:47 PM
TurboGibbs's Avatar
Default <TECH ONLY> Proven Peformance Packages! Forced induction GM
6.0 Turbo 10psi
YEAR, MAKE, MODEL: 2005 Chevy 1500 RCSB
ENGINE SIZE: 370ci (.030 6.0)
POWER ADDER SPECIFICS(IF APPLICABLE): Custom bult front mount turbo with PT76-GTS, FMIC, Meth injection, Eboost2 controller
HEADS: L92's stock intake valves and Manley exhaust
COMPRESSION RATIO: 9.0:1
CAMSHAFT SPECS: 218/223 @.050 .578/.524 114 LSA
VALVE TRAIN(PUSHROD LENGTH, ROCKERS ETC.): 7.400" trick flow pushrods with stock rockers and Patriot Gold dual springs
INTAKE MANIFOLD & TB: L92 Carb style intake with stock Throttle Body
FUEL SYSTEM: Siemens 60lb inj, Walbro 255lph pump, MSD voltage booster, converted to return style with aftermarket fuel rails and Aeromotive regulator
EXHAUST: Stock manifold on driver's side with log manifold with turbo mounted on passenger side. 3" downpipe with 3" QTP cut-out, 3" Corsa cat-back
TRANSMISSION & STALL/CLUTCH: T56 6 speed and Textrallia Exoskel dual disc clutch
REAR GEAR & TIRE SIZE: 3.73's with 275/55-20's(31.5" tall) 4.30's coming soon. 28" DOT's at the track.
SUSPENSION/TRACTION: lowered 2" in rear with Caltrac bars and Detroit Trutrac posi
TRUCK WEIGHT(ASSOCIATED WITH ET): ~ 4500
RWHP/TQ: 539rwhp 578rwtq on 7 cyls on old 317 heads and LS1 intake and 10psi. New set-up not together yet.
1/4 & 1/8 MILE TIME AND MPH: None
Old Dec 2, 2006 | 12:55 PM
TurboGibbs's Avatar
Default 4.8 Radix 13psi
ENGINE SIZE: 4.8
POWER ADDER SPECIFICS(IF APPLICABLE): Radix with custom large heat exchanger, 3.00" pulley, 13 psi
HEADS: Stock 4.8 with Comp 918 springs
COMPRESSION RATIO: 9.5:1
CAMSHAFT SPECS: 216/224 .575/.575 lift 114lsa (similar to Vinci Trucker cam)
INTAKE MANIFOLD & TB: Stock truck
FUEL SYSTEM: Radix supplied 39lb injectors,Walbro 255lph pump, Coolingmist meth injection and lots of it
EXHAUST: Pacesetter headers with ORY no cats, 3" Corsa cat-back
TRANSMISSION & STALL/CLUTCH: Stock 5 speed and stock clutch
REAR GEAR & TIRE SIZE: 3.73's with 275/55-20's(31.5" tall) 28" DOT's at the track.
SUSPENSION/TRACTION: lowered 2" in rear, spring clamps , Detroit Trutrac posi
RWHP/TQ: 445rwhp 478rwtq
1/4 & 1/8 MILE TIME AND MPH: 12.58 @ 109mph 1/8th- 8.01
Old Dec 2, 2006 | 01:08 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default 5.3L L33 Radix 9psi.
YEAR, MAKE, MODEL: 2005 GMC Sierra Z71
ENGINE SIZE: 325ci (L33 5.3L HO)
POWER ADDER SPECIFICS:Intercooled Radix,
3.20" pulley,
Alky Controll Meth injection.
HEADS: Stock L33 heads.
COMPRESSION RATIO: Stock 9.9:1
CAMSHAFT SPECS: LPE GT2-3
VALVE TRAIN(PUSHROD LENGTH, ROCKERS ETC.): 7.400" hardened pushrods,
stock rockers and 918 springs.
INTAKE MANIFOLD & TB: Radix intake manifold,
Stock Throttle Body
FUEL SYSTEM: Radix pump, fuel rails injectors, etc.
EXHAUST: Custom built True duals with Magnaflow catalytic converters and borla XR-1 12" mufflers.
JBA shorty headers.
TRANSMISSION & STALL/CLUTCH: FLT Level 5 4L65e / Yank SC2800
REAR GEAR & TIRE SIZE: 3.73's with 285/60/17(30.5" tall).
SUSPENSION/TRACTION: lowered 4" in rear with Belltech shackles and hangars and Detroit Trutrac posi.
TRUCK WEIGHT(ASSOCIATED WITH ET): ~ 5300lbs.
RWHP/TQ: 497whp 495rwtq @ 9psi.
1/4 TIME AND MPH: 12.65@109.27
Old Dec 2, 2006 | 03:01 PM
1SlowHoe's Avatar
Destroyer of Transmissions
YEAR, MAKE, MODEL: 2002, Chevy, Tahoe
ENGINE SIZE: 6L
POWER ADDER SPECIFICS(IF APPLICABLE): Radix/2.75" pulley
HEADS: Stock 317 casting w/ dual springs
CAMSHAFT SPECS: 210/218 .551 .551 112lsa (this week)
VALVE TRAIN(PUSHROD LENGTH, ROCKERS ETC.): 7.4" hardened pushrods / stock rockers
INTAKE MANIFOLD & TB: N/A, Stock TB
FUEL SYSTEM: Inline 255lph Walboro / Boost-A-Pump / 42# SVO injectors
EXHAUST: Pacesetter LT's/ Magnaflow cats / Magnaflow mufflers / 2.5" true duals
TRANSMISSION & STALL/CLUTCH: FLT65E Level 5 / PI 10.5" triple disc 2600
REAR GEAR & TIRE SIZE: 4.10 gears / 305/35/24
SUSPENSION/TRACTION: Eibach 2/3 drop / Eaton Posi
TRUCK WEIGHT(ASSOCIATED WITH ET): 5800lbs (no ET)
RWHP/TQ: 450/460
1/4 & 1/8 MILE TIME AND MPH: N/A
Alco
Jul 20, 2016 04:53 PM
1989k1500
Sep 29, 2015 10:53 AM
Chevy305
Sep 28, 2015 09:21 PM
vmaxpro
Sep 28, 2015 11:10 AM
Closer_2001
Sep 24, 2015 09:15 PM
