Tbss manifold swap/fuel PSI issue
Old May 5, 2011 | 11:00 AM
  #21
bonj87's Avatar
pic of my filter setup...
Old May 24, 2011 | 10:36 PM
  #22
Mangled03gmc's Avatar
Baltimore Whore
So any noticeable gains, or SOTP feeling?? Had a retune done yet, did you use your MAP sensor from your old intake??
Old May 24, 2011 | 10:42 PM
  #23
bonj87's Avatar
yes on map sensor.. but its loose. id like to get a tbss one
SOTP.. YES... much better throttle response.
Old May 24, 2011 | 10:45 PM
  #24
Baltimore Whore
Good to here, I was not sure if the one that comes with the intake TBSS will plug into the truck plug?? Can you verify it will work with the truck plug?( TBSS map that is), have ya been retuned yet??
Old May 24, 2011 | 11:04 PM
  #25
1slowz71's Avatar
i believe the tbss map is the same plug style as our trucks but it is a bit wider since the port on the manifold id bigger , but im sure you guys know that already , but i dont know if it will work i havent done my swap yet....
Old May 24, 2011 | 11:10 PM
  #26
Baltimore Whore
Ok ok, I am having a brain fart here.. So the plug is the same, and is wider or is the sensor it self wider.. sorry hahaha
Old May 24, 2011 | 11:13 PM
  #27
1slowz71's Avatar
the plug it self is the same as in our trucks , but the breather as in were the orange ruber is at is wider , if you were to put the 1 off you stock intake manifold it will be loose and have an air leak ....
Old May 24, 2011 | 11:16 PM
  #28
Baltimore Whore
Oh ok, I am golden then as i have the one that was in the TBSS intake.. Guess I will find out in a few weeks when i go to do the install..
Old May 24, 2011 | 11:20 PM
  #29
1slowz71's Avatar
did you buy the actual tbss manifold or the nnbs , the map on the nnbs has a diffrent plug ?
Old May 24, 2011 | 11:22 PM
  #30
Baltimore Whore
No this is a TBSS intake manifold, it also has the MAP sensor with it.. Also as for the MAF ( think you were reff'n to MAP, I got a Dr X box so no bigge there...
