tbss intake and 243's installed
Old Nov 17, 2008 | 08:51 PM
  #21
95 bright teal's Avatar
Sounds like a good setup, cant wait to hear how far you dip into the 12's!
Old Nov 18, 2008 | 05:33 AM
  #22
tdrumm's Avatar
Originally Posted by MGMC
i used the dr.x harness (torquerushdotcom) with a stock tbss 90mm throttle body that came with the manifold. I also used the tbss fuel rails with my 8.1 injectors. i got rid of the evap crap, and plugged the passenger side vent line on the valve cover. thats pretty much all to it
Any mods needed to mate the 8.1 injectors with the TBSS rail?
Old Nov 18, 2008 | 11:52 AM
  #23
Truckshop's Avatar
Originally Posted by tdrumm
any mods needed to mate the 8.1 injectors with the tbss rail?
nope. Just put them in.
Old Nov 20, 2008 | 06:34 PM
  #24
MGMC's Avatar
12 Second Club
I went to the track last night and ran a best of 12.7@105. my best time so far, before the stock 243's and tbss manifold i ran a best of 13.1@103. there was a 15 degree difference in temp at the track that really helped
Old Nov 20, 2008 | 06:43 PM
  #25
andrew383's Avatar
traveling mod
congrats!!! does it "feel" faster
Old Nov 20, 2008 | 06:50 PM
  #26
dlt76028's Avatar
thats a pretty good increase man. wonder how much of it was from the increased compression of the heads? do you know what your cr is now?
Old Nov 20, 2008 | 07:07 PM
  #27
Nice times! is this on street tires or did you get some slicks?
Old Nov 20, 2008 | 07:23 PM
  #28
MGMC's Avatar
12 Second Club
thanks guys! the run was full weight, system, spare, 1/2 tank, with street tires. i know the temp decrease helped along with the higher cr. im sure the intake/tb helped some. my cr is around ~10.2 . the stock 243's bumped me up almost 1 point in compression
Old Nov 20, 2008 | 08:33 PM
  #29
skyhighsami's Avatar
no title here
Then your CR should be closer to 10.5 Did you adjust your tune at all when you did this swap?
Old Nov 21, 2008 | 06:19 PM
  #30
MGMC's Avatar
12 Second Club
tune adjustment was the first thing done. what formula you using to get that cr? with a stock .53 gasket i was getting 10.2
