Sounds like a good setup, cant wait to hear how far you dip into the 12's!
Originally Posted by MGMC
(Post 4054143)
i used the dr.x harness (torquerushdotcom) with a stock tbss 90mm throttle body that came with the manifold. I also used the tbss fuel rails with my 8.1 injectors. i got rid of the evap crap, and plugged the passenger side vent line on the valve cover. thats pretty much all to it
Originally Posted by tdrumm
(Post 4054514)
any mods needed to mate the 8.1 injectors with the tbss rail?
I went to the track last night and ran a best of 12.7@105. my best time so far, before the stock 243's and tbss manifold i ran a best of 13.1@103. there was a 15 degree difference in temp at the track that really helped
congrats!!! does it "feel" faster
(Post 4057008)
Nice times! is this on street tires or did you get some slicks?
thanks guys! the run was full weight, system, spare, 1/2 tank, with street tires. i know the temp decrease helped along with the higher cr. im sure the intake/tb helped some. my cr is around ~10.2 . the stock 243's bumped me up almost 1 point in compression
Then your CR should be closer to 10.5 Did you adjust your tune at all when you did this swap?
tune adjustment was the first thing done. what formula you using to get that cr? with a stock .53 gasket i was getting 10.2
