tbss intake and 243's installed
Old Nov 15, 2008 | 05:33 PM
andrew383's Avatar
traveling mod
Originally Posted by BigCountryx
Never heard about this, I ran an x-link on my "car" 90mm without any noticeable problems, you have a link with more details?
the air flow is different and causes an idle and shifting problem,now for the maggie guys its a different story
http://www.tbssowners.com/forums/showthread.php?t=4799
Old Nov 15, 2008 | 06:04 PM
andrew383's Avatar
traveling mod
hey MGMC you should have bought this one
http://www.tbssowners.com/forums/showthread.php?t=6018
Old Nov 15, 2008 | 11:53 PM
MGMC's Avatar
12 Second Club
damn, thats a bad b*tch right there
Old Nov 16, 2008 | 06:18 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Originally Posted by dlt76028
who makes a 90mm dbc throttle body for the tbss conversion?
For 99-02 trucks you can run a 90mm UMI T/B Chris thunder550 Had one.
Old Nov 17, 2008 | 03:18 PM
1bigcam's Avatar
will the trailblazer ss tb plug in to a 03 silverado or how do i get it to work ??
Old Nov 17, 2008 | 04:10 PM
skyhighsami's Avatar
no title here
I was wondering the same thing about what TB to use. I think people are having to get a Dr X harness and run a Corvette throttle body or something like that. I wanted to make sure about this as I am starting to horde parts for my truck and Camaro build
Old Nov 17, 2008 | 06:36 PM
Truckshop's Avatar
you need the torquerush harness for either t-body to work.
Old Nov 17, 2008 | 06:59 PM
MGMC's Avatar
12 Second Club
i used the dr.x harness (torquerushdotcom) with a stock tbss 90mm throttle body that came with the manifold. I also used the tbss fuel rails with my 8.1 injectors. i got rid of the evap crap, and plugged the passenger side vent line on the valve cover. thats pretty much all to it
Old Nov 17, 2008 | 07:09 PM
Truckshop's Avatar
did you disconnect your pcv?
Old Nov 17, 2008 | 08:13 PM
no title here
How does this intake compair to a L92? I have been reading on that intake and those heads and they seem pretty good. Since I am in the air about what heads I will run I am up in the air also about intake. Thanks
