TBI 350 "rattle"
Old Apr 4, 2007 | 11:52 AM
Element's Avatar
Default TBI 350 "rattle"
Just bought a 1987 Blazer with a 350TBI. After basic tune-up stuff, it runs pretty well, but there's a noise it's making that has me worried. It only happens under heavy acceleration, and sounds like a kid with a marble in a tin can is shaking it, like something is loose and flopping around - maybe a rocker arm? It doesn't have a real rhythm, as far as "tick tick tick", as it's more like "rattle................rattlerattlerattle......... .................rattle rattle" (if that makes any sense at all).
The engine idles and accelerates fine, just making that noise that has me worried.
Old Apr 4, 2007 | 11:59 AM
TurboGibbs's Avatar
sounds like valve rattle. There is probably a lot of carbon built up in the cylinders. Higher octane gas and or run some seafoam through the TB to clean it out.
Old Apr 4, 2007 | 01:37 PM
Element's Avatar
I've run Seafoam through once, but I'll try again and see what happens. Any other fixes for that?
Old Apr 4, 2007 | 01:41 PM
TurboGibbs's Avatar
reving it up and trickling water in the TB will break loose carbon as well as tranny fluid the same way. If you put a tank of 93 in it and it stops you'll know what the problem is then.
Old Apr 4, 2007 | 01:51 PM
shandy294's Avatar
How about timing that's too advanced?
Old Apr 4, 2007 | 02:26 PM
Element's Avatar
I'll try running some Seafoam through the TB while the truck is running, and I'll put another can through the brake booster line.
hodge9386
Oct 25, 2015 01:26 PM
wickedRCSB
Oct 10, 2015 09:29 PM
gmcyukon
Oct 3, 2015 11:03 PM
ice17
Sep 22, 2015 05:18 PM
cousblake11
Sep 9, 2015 06:52 PM
