In-tank fuel pumps for trucks?
What in-tank pumps are you guys using? I just found out that Racetronix doesn't have a compatible system for me so I need to find some other suggestions. Will be running 62# injectors supporting 700+ rwhp.. Thanks.
:cheers: |
they have something just for you but dont really like to sell it. probably take you a couple of months to get if you could talk them into selling you one.
check it out, lots of pic's >> http://www.neufamily.org/03html/fuelsystem.html |
do you have a part number for it?
You might want to look into the Fuel Systems that Speed Engineering has out now. They look really nice for high HP applications for our trucks.
The walbro one for the 2004 H2 Radix is a intank pump. PITA to install but works great. No noise :)
two walbro gss340s, $4.79 in brass fittings, some marinetex, a relay, a hobbs switch and some wiring and you have the same thing that racetronix sells. It's an easy thing to do, and you can do it on your own time instead of sending your fuel pump carrier to Canada and waiting.
I recon those are the In-line walbro pumps... So you think that you could run two in-lines and have the stock in-tank pump flow enough fuel to get the gas to those pumps? |
No, he is talking about building your own dual in-tank setup. I did the same thing and it wasn't too hard. Far easier than dealing with racetronix. |
Originally Posted by L-EATER
:stupid:
No, he is talking about building your own dual in-tank setup. I did the same thing and it wasn't too hard. Far easier than dealing with racetronix. the price they charge isn't too bad once you add up all the stuff they use but they are dificult to deal with. no phone and 2 days to return emails sucks. i did just order some injectors from them and got them in less than a week :) |
