Tahoe rst brakes, affordable big brakes down the road?
Old Apr 7, 2017 | 07:33 PM
GMCtrk's Avatar
Default Tahoe rst brakes, affordable big brakes down the road?
Anyone seen the optional brakes on the '18 tahoe rst?
16" duralife rotors with brembo calipers.
Wonder if these will be available through GM for significantly less than the Wilwood brakes
Old Apr 9, 2017 | 02:57 AM
cheyenne383's Avatar
TOWN CRIER
I keep looking at the article on the RST package. We picked up a 16 burb and there are definitely some appealing options. The color matched front end is way more attractive and the thought of 16" rotors with Brembo calipers had me looking forward to a few years from now.
I keep eyeing the Borla cat back but $1100 for a couple of pipes and a muffler have me second guessing.
Old Apr 9, 2017 | 06:39 AM
vettelovralexand's Avatar
Good to know i wasnt the only one thinking about the brakes when that was announced.
Old Apr 9, 2017 | 05:27 PM
SnakeOiler's Avatar
Those brakes are currently an option for trucks and a GM Accessory. MSRP $2700
Old Apr 9, 2017 | 05:33 PM
Any part numbers for the rotor and caliper? What is the smallest wheel they fit? 20s?
Old Apr 10, 2017 | 06:48 AM
SnakeOiler's Avatar
Chevy - 84263234 - has bowtie with CHEVROLET on the caliper
GMC - 84263235 - has "GMC" on the caliper
Minimum 20" GM accessory wheel (other 20" could fit of course)
Summit sells it for $2550
GMPartsdirect $2264
Old Apr 21, 2017 | 10:44 AM
Sideways the Seven's Avatar
First thing I thought about when I saw the Brembo option but I had no idea it was available from GMPP already. Anyone have an idea of how much of a PITA it would be to swap on a GMT900?
Old Apr 22, 2017 | 03:27 PM
SnakeOiler's Avatar
Take off the old caliper/rotor, put the new caliper/rotor on. It just brakes.
Old Apr 24, 2017 | 12:12 PM
01SilveradoJakee's Avatar
Drove a Camaro with the brembo braks options when i was looking for something different (2015) and droce it without the brake upgrade.
IMO GM should just make anything with a v8 with brembos. The difference is Huge and wirh brembo is easy and gentle when you want it and aggressive when you need it. Extra sercurtiy on the crazy road in todays world.
Old Apr 17, 2018 | 10:21 PM
GMCtrk's Avatar
Guys, bringing this back. I can't take the factory brakes on my 02 tahoe much longer. I do a lot of driving for work now and the brakes can get very hairy at times coming down from highway speeds.
GM lists these as for 14+ trucks. Is there any reason this wouldn't work on the 99-07 NBS?
Any comments on Brembo versus the Wilwoods in general? A couple things I've noticed comparing these two is that the Wilwood uses a 2 piece rotor versus 1 piece on the Brembos. The brembos are slightly larger 16.1" vs 16" (insignificant I presume). Also the GM kit looks like a true bolt on. No replacement caliper bracket and uses stock brake hose (wilwood requires their own SS lines).
