tac mod #
Old Jun 27, 2009 | 04:41 AM
RickLowpez's Avatar
Default tac mod #
need a tac module # to use a 90mm ls2 throttle body on a 04 chevy truck.got the spear tech harness already.does a tac module even exist to make this tac and throttle work.dont wanna use the dr x box so need help thanks guys
Old Jun 27, 2009 | 06:08 AM
neilownz's Avatar
This place sells wiring pigtails if that helps any. It is probably just figuring out what the stock wires do and wiring up something to change the pin locations...
http://www.eficonnection.com/eficonn...omponents.aspx
12574221 is that it?
Speartech sells a tac module also
Yikes like $150 for a new one. Junkyard time!
There's one on ebay for $75 if that is what you need.
Old Jun 27, 2009 | 08:47 AM
Truckshop's Avatar
you need the older tac module. 02 i think. why not use the torquerush adaptor? it works great on my 04. plus from what i have read the speartech setup wont open 100%.
Old Jun 27, 2009 | 02:40 PM
RickLowpez's Avatar
well i know guys but i had used the drx box before and had lot of little issues so decided that tac mod was more straight forward.i was just trying to see if i had the right mod. for thr ls2 throttle body in a 04
Old Jun 27, 2009 | 03:01 PM
Truckshop's Avatar
i had issues trying to use the tbss t-body. once i switched to the car style i had no more problems. its been over a year and it is my daily driver.
Old Jun 27, 2009 | 10:24 PM
RickLowpez's Avatar
by any chance do u have the tac part number
Old Jun 27, 2009 | 10:51 PM
KySilverado's Avatar
Part # 12574221, as already posted above.
Old Jun 28, 2009 | 04:26 AM
RickLowpez's Avatar
thank u
madmann26
Apr 29, 2020 09:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
bisqikss
Sep 27, 2015 09:40 PM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
