Synthetic for gear oil?
I am about to intstall a 3.73 unit on my truck and was wondering if I need to replace the oil or use the stock one? Some say the original oil works and some say any gear oil is better than the stock. Will the original oil work?
What's up with synthetic?
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
The stock differential oil IS synthetic.
GM recommends using synthetic SAE 75W-90 gear oil (part# 12378261).
If you decide to throw in a posi with the gears, for example an Eaton LSD, then you'll have to use the conventional oil that Eaton recommends plus the LSD additive, it's a friction modifier.
Here's an article on how to change your differential oil.
http://www.gm-trucks.com/IAR_RearDifffluid.shtml
I just got the Eaton installed ($350 off ebay) and I LOVE it. I can't explain how much fun it is. Doesn't take long to learn how much throttle you need to give it to break the tires loose around corners, or anywhere for that matter. Off the line it hooks up great.
This is the only one I've had, but I know Auburn makes one, less expensive, but you can't rebuild it unlike the Eaton.
Corvette454l88
Sep 1, 2016 01:24 AM
Noah Burns
Sep 7, 2015 05:50 PM
tgui
Aug 15, 2015 12:27 PM
