synthetic to conventional
I put 75,000 miles on w/15-w50 conventional, then went Whippled. After 15,000 miles, I switched to 10-w30 synthetic for one oil change. Now I took off the blower. What would happen if I went back to conventional?
Originally Posted by red53gmc
Nothing.
the synthetic oil doesnt alter the properties of the metal.........
the old wives tale ussually goes the other way. saying that you will have problems with synthetics leaking from gaskets that wouldnt let dino leak from
i dunno about using that 15-50 oil tho. thats a lot thicker than what these things were designed to use
I run a 45 truck fleet of garbage trucks, so I just used to take what we run. The thickness is the reason that I went synthetic.
Noah Burns
Sep 7, 2015 05:50 PM
