SUPERCHIPS TUNER KILLED MY TRUCK
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Stove:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Puffnstuff:
<strong>In the installation instructions they tell you which fuses to pull to disable onstar before you even connect the tuner up. I've got superchips tuning and I love it - it absolutely rocks. Night and day difference between stock tuning and it. Sorry to hear about your problems but reguardless if you've got onstar or not you should've read all the instructions before trying to install it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">NO PLACE IN MY DIRECTIONS DOES IT EVEN MENTION ONSTAR, LET ALONE PULLING A FUSE. I can scan them if you like. I read the directions top to bottom twice before even getting the tuner out of the box. Than sat in the truck and went step by step folloeing word for word. I didn't make a mistake. You are one of the reasons that I bought the tuner. You have had nothing but +'s to say about it. I thought that you had install problems also?? My programmer # is 2285.
later</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I got the same part number and I got 1 instruction sheet and another sheet about the OnStar.
[/qb][/QUOTE]I got the same part number and I got 1 instruction sheet and another sheet about the OnStar.[/QB][/QUOTE]
Well that is just wrong. Someone on that end didn't pack the other instruction sheet in my box. The first thing that tech support asked was if the truck was equiped with onstar. That may be the root of my problem then. Thanks for the reply.
later
later
Stove,
Yes I did have to send my unit back to superchips for an update. Yes it did activate the passlock fuel shut off but disconnecting the battery cleared that. After I got my tuner back everything went fine, no problems whatsoever. I'm sorry to hear about all of your trials with your tuner. They should've put the additional instruction sheet in your box, shame on them. If you need to see it I could probably scan it and email it to you. If you need it email me at puffnstuff12@***.net and I'll hook you up with it.
<strong>Stove,
Yes I did have to send my unit back to superchips for an update. Yes it did activate the passlock fuel shut off but disconnecting the battery cleared that. After I got my tuner back everything went fine, no problems whatsoever. I'm sorry to hear about all of your trials with your tuner. They should've put the additional instruction sheet in your box, shame on them. If you need to see it I could probably scan it and email it to you. If you need it email me at puffnstuff12@***.net and I'll hook you up with it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well here is the latest update. According to superchips tech, the onstar instructions were not included because they have solved that issue in the tuner itself so it is not necessary to remove a fuse. I'm not so sure.
My truck is alive again one pcm later. Also replaced the fuel pump for low pressure, but I don't believe that was related to the tuner problem. Tuner itself is one its way back to superchips.
I think that I want to to buy an extra PCM just in case. How would I go about getting it programmed?? I don't think I can just take it into the dealer and ask to have my vin info programmed into it?? Any ideas?? Is there another way to get a pcm programmed???
later <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>Stove,
You can find valvegod here, just in case.
i've been dealing with him for the last 10months and he's been real helpful. i would recommend him to anybody so far. my pump went out in my new ls1 and he's going to reimburse me when i send him the old pump.
Shaun Carter
SMC Performance, Inc.
Phone: 248-276-0483
Specialize in GM LS1 & GEN 3 Small Blocks.
We accept Visa, Master Card, American Express, Money Order & Paypal
good luck,
Shaun Carter
Phone: 248-276-0483
good luck,
Valve god is the way to go, i was happy with his service, and my pcm was shipped the day i ordered it. I nuked a pcm from piggybacking my hypercrap and my supershits programmer. not only did that fry my pcm, it locked both programmers. I had to send back the supershits and they sent a new one. good luck.
J
J
Well superchips shipped a new programmer to me today, to my surprise it looks different than the old one and has a different part number. I suspect there might have been a batch of bad programers out there. Well as soon as my truck returns from the dealer I will try it out.
when programming the pcm you must install battery charger on low or medium power on battery. due to the fact that with the key on and the data downloading if the battery volts drops below 12.0 volts it will lock the pcm up. you must get a new one from the dealer. i know this due to the face may dumb techs at the dealer i work at do this all the time. if it happens you can try to remove the positive cable from the battery and touch it to the negative cable some times this unlocks the pcm
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by cadyman:
<strong>when programming the pcm you must install battery charger on low or medium power on battery. due to the fact that with the key on and the data downloading if the battery volts drops below 12.0 volts it will lock the pcm up. you must get a new one from the dealer. i know this due to the face may dumb techs at the dealer i work at do this all the time. if it happens you can try to remove the positive cable from the battery and touch it to the negative cable some times this unlocks the pcm</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Mine doesn't lock below 12 volts.
