Supercharged daily driver's......
Old May 27, 2005 | 09:42 PM
  #21
BlownChevy's Avatar
blownerator
25 Year Member
Dont get me wrong, I loved the 4:10's in my old truck. This one is headed down a different path, that is all.
Old May 27, 2005 | 09:50 PM
  #22
white1's Avatar
Originally Posted by jmproductions
Seems like a lot of confusing stuff here. I went from 3.73's to 4.10's and the truck accelerates faster, period. You will not lose top end power. Maybe some top speed if you have enough engine to tach out OD, but you guys shouldn't be trying to go that fast anyway, these are trucks.. HE HE. Some people think that they have lost power because their truck won't downshift into 2nd anymore at a certain speed. Yes, it will lower your shiftpoints but you will reach your powerband faster and more often getting to the same mph with lower gears. The result is lower ET. Now all that being said if I had an automatic and I drove the truck daily I would stick with the 3.73.
I'm currious how fast you would have to be going to top out O/D with 4.10's on the average 2wd tire? At lets say the stock red line 6000 RPM?
Old May 27, 2005 | 11:07 PM
  #23
Mr. Sandog's Avatar
Knowing what I know now, I would have kept the 3.73's in and purchased a tight, higher-than-stock stall converter...say, around 2600-2800. That way, I would have the best of both worlds - boatloads of torque off the line/when downshifting (better than the 4.10's, I am sure ), and cruising RPM's at TCC lockup much more in line with the desires of my ears, foot, and wallet.
What some people don't realize is that numerically higher gears have a less effective range. Sure, they get you off the line more quickly, but you shift sooner, because you run out of gear sooner. So those same gears that get you off the line quickly, run out of steam once you are moving.
I experienced a real-world loss of freeway torque and HP when I switched to 4.10's, and it was significant. This had nothing to do with my shift points, it had to do with having less gear to work with once I was up to speed. Talk to guys with 3.42's....they might lose off the line, but ask them who owns the freeways...
Old May 27, 2005 | 11:10 PM
  #24
BlownChevy's Avatar
blownerator
25 Year Member
I never lost a freeway race with my RCSB and 4:10's
Old May 27, 2005 | 11:12 PM
  #25
Mr. Sandog's Avatar
The one with the 6.0L and the 2.5" pulley?
Old May 27, 2005 | 11:14 PM
  #26
moregrip's Avatar
what a rush!
last time I checked 4.10's had plenty of gear at freeway speeds.
  #27
BlownChevy's Avatar
blownerator
25 Year Member
2.9
Old May 27, 2005 | 11:55 PM
  #28
1SlowHoe's Avatar
Destroyer of Transmissions
I assume you guys are talking about trucks on 16 or 17" tires. When you're runnin' 20's to 24's I think the 4.10 is in order. IMO. I am swapping to 4.10's in a few weeks. I'll let you know how they work out.
Old May 27, 2005 | 11:56 PM
  #29
BlownChevy's Avatar
blownerator
25 Year Member
I have 20's but the overall diameter is the same as stock.
Old May 28, 2005 | 12:27 AM
  #30
1SlowHoe's Avatar
True. And 12sec5.3 is a rc so maybe 4.10's would be overkill. But hey, maybe he's not looking for 100% streetability. I'm olny switching to 4.10's cause my 24's make the stock rims look like golf cart tires.
