Super damper pulley belt correct
I could have first place to use string to measure belt but my truck is at friend house. I’m trying order online anything i can find correct belt. Stock belt didn’t fit due my aftermarket super damper pulley on 06 Silverado. See if anyone who have same this issue and find correct belt. See if you can share with me quick ? If yes. Very much appreciate.
ATI provides the belt numbers required on their website based on your application. You should have got the sheet with the pulley too but in case you didn't it's all on their site.
You didn't specify if it is stock size or under drive but I'm guessing the latter since it didn't fit
