stupid light!
Old Nov 16, 2010 | 08:48 PM
Sinistersilverado's Avatar
Default stupid light!
my check engine light has been on forEVER! i put my code reader on there and code 307 popped up with a misfire on cylinder 7. I swapped the coil out with cylinder 4 and its still reading misfire on 7. Changed plugs and its still the same thing. bought new wires and STILL! what can be causing this? also as i'm driving it will sometimes blink which i'm guessing thats when the misfiring is happening?
Old Nov 16, 2010 | 08:53 PM
grey matter 04's Avatar
13 Second Truck Club
you dont have a broken valve spring on #7?
meaning you changed plug ,wire and swapped coil and still have the issue
Old Nov 16, 2010 | 09:11 PM
true, i didnt think about checking that. thanks a lot.
Old Nov 16, 2010 | 11:01 PM
welcome
I been down this same road before !!
Old Nov 16, 2010 | 11:19 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I would do a quick compression test (infamous #7.....), and I'd also swap the injector to another cylinder.
Old Nov 17, 2010 | 12:52 AM
BG06SILVERADO's Avatar
It seams that you guys have experience on the situation, but a blinking check engine light usually means a danger to engine/emissions system.. damaged springs or injectors qualify as engine/emissions danger..
Old Nov 17, 2010 | 01:30 AM
Actually, a flashing check engine light means the misfire is "catalyst damaging". Which usually involves unburned fuel getting into a cat. A bad injector CAN cause this(and isn't uncommon), and so can a cracked piston. There are several things that can cause it.
Old Nov 17, 2010 | 01:56 PM
catalyst=emissions
RustyD
May 23, 2016 07:04 PM
dantheman1540
Feb 24, 2016 09:56 PM
carid
Oct 28, 2015 08:24 AM
carid
Oct 1, 2015 09:22 AM
Lthompson
Sep 21, 2015 07:06 PM
