STS Dyno #'s - 10psi
#61
Originally Posted by bud8fan
if i remember right..i think he told me 3300 lbs...something like that...he's got everything cut off the farmtruk thats not being used...
thats crazier than the dyno #'s
#62
Check sig for 10 psi on a 346 on a dyno jet, if numbers are inflated then hes more likely in my area. At 14psi im over 700 though. These kits work boys, wait until I break 800rwhp in april
#64
Originally Posted by 02denali
the numbers on allens dyno run less than dynojet. if you go to his and dyno then to as dynojet his numbers are lower.
That's what i want to hear
It's just some are skeptical because he is essentially gaining 260rwhp from just 4-5psi more.
#66
and an intercooler as well.
True but it still 370rwhp from just 10psi. That is a ton of HP and out of most peoples calculations.
#68
Not calling B.S. or anything, but something is not exactly right with the numbers. I dont know if it is in the dyno or what, but that is about 200 more hp than any other STS kit on 10 psi that I have seen, f-body included. Just dont anyone to be disapppointed when they dont get the same #'s with the same setup....*No flames intended, I know everybody gets a little protective over their STS kits.*
#69
Keep in mind he is one hell of a tuner! he probably tweaked that PCM 100 times!
#70
Is it possible this was a mistake?
