Are stock ported heads worth IT.
I am looking into buy a set of stock ls1 heads and porting them is it worth the truoble. the heads will be from 100-450 and port work 450-600 so a total of 550-1050 not too much money but the install will be time consuming and an install kit is 250 so im looking at 8-12 hrs of work and 800-1300 dollars installed. I dont even know if the hp gains will be that graet has anybody gone this route. I also need to know what heads i should look for ls1 5.7, 5.3,4.8 or are they all the same what size CC do they have need info bad.
Thanks
Thanks
For the money you can get a set of STG I or even II heads from many of the sponsors to the right ------> that will be tons better.
As for the type, let your current and future mods be the deciding factor. Also check out this thread https://ls1tech.com/forums/showthread.php?t=111207 located in the LS1-LS6 Internal Engine section. The best location for most/all your questions.
sauldgold
Jul 23, 2015 02:15 PM
