stock gaskets or cometic .040's???
Old Sep 27, 2007 | 07:21 AM
Grumpy5.3's Avatar
Originally Posted by ap2002
stew why not use the stock gaskets and just mill the heads .030 and it should put you close up there...? do you have the set of 243's already?
shaving heads is alot cheaper than those cometics. BUT you will need to check your pushrod length, just to be sure
Old Sep 27, 2007 | 09:35 AM
bluecajun5.3's Avatar
11 Second Truck Club
around how much it is to mill them then?
Old Sep 27, 2007 | 10:54 AM
BigKID's Avatar
I presume these are going on the stock LS1 bottom end?? If so the .040 Cometics will give you a bitter quench area for some detonation protection. The Cometics are also resuable so if you had to pull a head for something, you wouldn't be out the price for another stock gasket. I spent the extra money for the Cometics when I did my LS1 hand ended up pulling the heads twice so they ended up paying for themselves.
Old Sep 27, 2007 | 11:10 AM
silver-mod-o's Avatar
Hunt&Fisherator
shops normally charge anywhere from $50-$100 to mill a set of heads...
-I'd go with the cometics Stew... that way, if you want different heads in the future, you can sell an unmolested set and probably move them easier.
Old Sep 27, 2007 | 03:57 PM
ap2002's Avatar
to mill them here is $75...
Old Sep 27, 2007 | 09:00 PM
Unhappy
Originally Posted by Quik
thanks, it doesnt sound like that anymore. never made anytimes. hit 1200 miles and floated a valve. wiped out cylinder. now im in the long process of rebuilding for boost
Sorry to hear. What went a miss? Weak valve springs?
How's the rebuild coming along? What do you have planned?
Jim
Old Sep 27, 2007 | 09:04 PM
i would only be losing .012 so i should be able to keep the 7.400 pushrods i have now.
jim im broke into the 12's N/A last weekend. im not sure if you knew that i swapped a LS1 into the truck too.
Man that's awesome. Can't believe you have came this far already. If you have the heads off or will be possibly taking them off, why not send them off to a machine shop to be worked over and get a bigger cam? Not sure if you already put a bigger cam in, but just a thought.
Did you get you a new job yet?
Jim
Old Sep 27, 2007 | 09:27 PM
KB's Avatar
KB
13 Second Truck Club
If you get them milled .030 you might run into the same problem with the pushrod length, so I guess I would go with whatever is the cheaper route. I was going to get mine milled .030 then found out my comp 7.4's would be too long so I had to limit it to .015 max. I only paid $60 for the mill work.
Old Sep 28, 2007 | 10:36 AM
TXsilverado's Avatar
jim i havent seen the real potential of my current cam yet 226/226 584/584 112. im always in the heat, on a slippin tranny, or some other lame reason i couldnt make a good pass. last time at the track everything was working perfect on the truck and got to get a glimpse of how its guna do this winter. cant wait for winter times trappin 103-104 in the warm felt good.
Old Sep 28, 2007 | 07:11 PM
You going to get that tranny fixed or what? I can hear that FLT level 5 tranny calling your name....
Anyone know if Vince at FLT beefed up his level 5 4L65E kit? Last I heard, he found a few parts that still could use some strengthening to kick up the HP/ TQ ratings of his level 5 tranny.
Just wondering.
When you heading out to the track Stew? Later at the end of Oct or mid Nov?
Let me know, I might want to head out with you possibly.
Jim
