still have edit problems
Need More N2O Mod
ok i now have a pcmcia card that is a serial port and i still cannot get communication with the pcm. i really dont know what to do? on the little black box that the obd plugs into there are little led lights. how many of those should light up? i have the first three on the right side. and they blink
FWIW, I still have not been able to solve that problem with mine either. But I haven't really messed with it since before the spring break shootout either, and I also have the PCMCIA card.
Hey Matt,
The 3 blinking lights are good - on the side closest to the PC. That means the Edit converter box is getting power from the PCM (first light) and that the comms are detected (next lights). I have heard that the light closest to the PCM means the data bus is busy... not sure on that one.
Normally I do the following:
disconnect PCM harness, connect bench cable, connect clips to battery, turn on switch in cable, wait 30+ seconds, connect cable to PC and start up ls1prog, connect OBDII connector to PCM (here I get the 3 lights), select a file name for read or flash, start read/flash.
Are you using a bench cable or the under-dash connector?
Need More N2O Mod
Finally got it to work. well i had to use my work laptop because it has a db9 serial port built in. its a cheap $500 dell. and it worked as soon as i plugged it up. thanks for everyones help. i am sure i will be needing more with tuning
when i wiped my laptop and reloaded a fresh os with no bs programs on it, mine would'nt work either. somehow it assigned the wrong comm port as the default. if you have'nt already go in to system and see if the right port # is assigned. also see if it says there is sharing conflict. just a shot.
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
