-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Speedo Wire (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/speedo-wire-344728/)
closet red neck Jul 18, 2005 07:01 PM
Speedo Wire
Can anybody tell me were and what color the speedo wire is on an 02 truck??? Want to hook up a speedo...Thank you very much in advance!!!
chevymec Jul 18, 2005 08:38 PM
Well the speedometer runs off the speed sensor, in your case the rear of the transfer case. Explain more about why you want to hook up a speedo?????
TURBHOE Jul 18, 2005 09:27 PM
https://www.performancetrucks.net/fo...d.php?t=344667
i think this is why
closet red neck Jul 18, 2005 10:31 PM
Originally Posted by 4.8T
Well 4.8 said it!!!! I just want to be different and to see if I could make it work. I think that it would be kinda cool!(maybe)
TURBHOE Jul 18, 2005 10:45 PM
yeah it should as long as it just needs an electrical signal and the right kind and amount. (ac or dc and voltage amounts) not sure about my truck but i'm 99% possitive my car is ac signal.
1slow01Z71 Jul 19, 2005 07:09 AM
Going to be dc and its going to be a wire coming up to the back of the cluster. Ill find out the wire color in a bit if no one else posts it up. Ill ahve to look on Alldata and find it.
closet red neck Jul 19, 2005 06:51 PM
Thank you very much!!!! I guess that this is the closest wire to tap into???
