Speed Engineering True Dual X Pipe Side Exit
#21
that’s exactly what i’m going to do. work has just been hectic for me so i don’t have any time off currently that works with the exhaust shop. i even thought about a little bigger size of tips but i’ll probably leave them
#22
Mine doesn't hit the crossmember at all but still sounds like a small leak, and I've done as much as I can for the leaks so I think it's just that header sound at this point on mine. The aluminum foil trick did a pretty good job at sealing the joints. I want to weld mine but at the same time hate the idea of it not being serviceable and having to cut it apart if I need to move or change something. I need flanges but having them done is pretty expensive. So f it, I'll live with mine the way it is.
#23
To me having it welded is no different than the stock y-pipe in terms of serviceability. I doubt you'd be able to separate that section without pulling both sides off the headers anyways. That's the only spot I have a peak I can't seal so it's getting welded this weekend.
#24
For mine on the curved section from driver header that connects to crossmember I used a small bead (definitely didn't cake it on) of copper RTV and these clamps and they worked out great. No leaks. I'm checking everything over later today so I'll post an update. These are the clamps I used as well
#25
I bet it did pick up, I wouldn't have thought so but speed engineering posted a dyno with that dual exhaust vs a single 3" setup and if I remember correctly it gained near 30hp. And it was a bolt on cam only truck. I always thought single 3" was close enough at that power level, obviously not.
I've been trying to figure out what I want to do next with the exhaust because I know mine could flow more. After seeing all this I think I'm gonna lean toward doing this setup.
Do you have any pictures of the tips and how they fit up to the truck/how they look on the truck? In the pictures I see the tips are separated by a couple inches? I assumed it would look better if the tips were stacked on each other but seeing it on the truck will tell.
#27
With stock if I need the manifolds out of the way I can move them, with non welded I can move the headers around a bit. With them welded I can't do **** without cutting it.
I got my leaks down to basically none with the foil wrap. I'm pretty sure the noise I hear now is just header noise and it's not bad at all. In other words.. it's so much better than it used to be that I'm satisfied and probably won't do anything more to it. But welding it all up is always in the back of my mind.
https://www.amazon.com/Dynomax-33272...3GVXY93F7R834N
It's in a thread posted up by them, I'll try to find it.
Agreed, the more power the more airflow there is that's being restricted
#28
update: little more drone over time. still not ridiculous but i think it was from e85. i have some 91 back in it and drove 45 mins to work and didn’t notice it as bad. didn’t have much time to check over clamps but I will next weekend.
L86 manifold and throttle body are on the way also
#29
Posted the wrong part of the post. Here is the right part
Added 2/18/16:
Ok, thought you guys would enjoy some actual dyno numbers of the true dual exhaust.
Vehicle:
-2008 Sierra Crew Cab 4x4
-6.0L Engine (Stock Bottom End & Heads)
-228 Camshaft
-Our 1 7/8" Longtube headers
-Stock 3" Cat-Back w/Magnaflow muffler welded in.
1100MD Mustang dyno:
Stock Cat-Back w/Magnaflow Muffler
-343rwhp
-331rwtq
Our 3" True Dual Exhaust
-367rwhp
-350rwtq
Gain: 24rwhp/19rwtq
No other changes were made to the vehicle besides the true exhaust swap. Headers were already installed. The thing we were most surprised with was the torque gain across the board. It didn't loose any bottom end. The larger 3" exhaust actually gained torque across the board.
Added 2/18/16:
Vehicle:
-228 Camshaft
-343rwhp
-331rwtq
-367rwhp
-350rwtq
Gain: 24rwhp/19rwtq
