Specific header/exhaust question
no title here
I am going to put some headers on my truck. I am between the OBX, Pacesetters, ASMs, and ARHs. My truck being a 6.0 has dual 3 inch into the muffle so I will not need the Y pipe. The OBX while nice seem to make spark plug access difficult, and the fitment issues also are there. The Pacesetters are nice and proven time and time again, but I like the way the OBX connect to the rest of the exhaust. I can have an exhaust made from the headers to the muffler and it won't be an issue. The ARHs are nice but kind of pricey, and they aren't as proven. I do want to run no cats so the Dynatechs are a no go. Anyway anyone with feedback feel free to give is.
no title here
The rest of the exhaust I am thinking will be a dual 3 inch inlet and single 4 inch outlet muffler and Magnaflow Duramax tail section. Unless there is a huge benefit from running 2 1/2 inch dual exhaust with an X and dual mufflers, or a single muffler with the X in the case. I have searched and it seems to be prefernce. I just don't want a nasty drone, right now I have a dual 3 inch inlet single 3 inch outlet Magnaflow with a Corsa resonator with Gibson shorty headers. .
This is just my opinion... I would get the pacesetter in the painted version.. Add some GOOD flanges or Vbands (That is what i did), mock up the rest of your exhaust, then send the headersout to to be ceramic coated inside and out (rest of the pipes are optional)... Basically that is exactly what i did, but with AEM headers... i can grab my headers about 20-30min after running them, before they took hours to cool down..
no title here
See I don't want to spend 500 for some headers and then have to use zip ties to keep my plug wires off the headers. If I do go with a dual setup up it will either have 2 mufflers and an X pipe, or have 1 muffler with the X in it. Like a Magnaflow, I want something that will sound good, and have 0 drone. Would the dual mufflers and X be better for flow and sound, if so what size pipe? Or would dual 3 inch into a single 4 inch outlet muffler be enough for flow? Or should I get the ORY and run a single 3 inch into a SI/SO muffler? My only problem with that is that Chevy made it with 2 3 inch pipes to the muffler, there had to be a reason. I will seriously consider sending the headers off and having them coated but I would much rather have them ready to go on as soon as I get them. Is the coating they come with garbage?
no title here
Dart 225 heads, 10.8 CR, 220/226 cam .600+ lift 112LSA , TBSS intake throttle body and injectors. Aside from that the truck will have a small stall in it like 2500-2800 and I might put a 100 shot on it at some point
