Source for new injectors?
Old Aug 14, 2003 | 02:04 PM
Scream's Avatar
MOOBIES Moderator
Default Re: Source for new injectors?
Well, I was planning on running the truck intake and accessories for a more stealthy install!
Are the AS&M Multec II's my only option to stay with the truck intake/fuel rail? Am I overshooting my injector needs? Could I get by with less injector?
Thanks!
Old Aug 14, 2003 | 03:22 PM
Ryan23silverado's Avatar
Oh, my bad
You would do just fine with the 8.1L injectors. They are the Multech II obviously and they would fit.
With your N2O fueling needs, I would run a wet shot (more torque this way, and you wouldn't have to worry about maxing the injectors like you would with a dry shot N2O) So, at this point, all you are having to worry about would be your fuel pump keeping up while on bottle. The 8.1L injectors should spport up to around 405hp. Do not take that as fact, I am just figuring that a ZO6 uses 26lb. Multech IIs and they come stock at 405hp.
Old Aug 15, 2003 | 10:07 AM
Scream's Avatar
MOOBIES Moderator
The 8.1s won't support 400-450hp will they? I don't think that would leave me any headroom at all. I plan on doing some sort of heads later on next year, so I don't want to have to swap out the injectors again.
Old Aug 15, 2003 | 10:23 AM
Racetronix's Avatar
LS1TECH Sponsor
Just to clarify...
The Bosch Ford Motorsport SVO injectors are pintle injectors.
The Multec and Multec Series II injectrors are ball / seat injectors.
The 25176061 injectors (we will have on sale soon) are 37.95lb/hr @ 300KPa and 43.82lb/hr @ 400KPa. These injectors will support 450HP or more depending on the BSFC of your motor and the max. RPM. The spray pattern is similar to most other Multec injectors. A wide spray pattern is not always best depending on the signal in the manifold and the injector's positioning relative to the intake valve. Disc injectors are a Lucas design now owned by Delphi and are listed on our web page as such.
Jack
Racetronix
Old Aug 15, 2003 | 10:32 AM
Scream's Avatar
MOOBIES Moderator
That's weird...I just found Racetronix's website through a google search!
Looks like I'm gonna have to break the bank to feed this damned motor. Grrrr......
What kind of money are we talking for these injectors? I see that AS&M 43lb injectors for roughly $420. Are your prices comparable to that?
Old Aug 16, 2003 | 12:07 AM
Racetronix's Avatar
LS1TECH Sponsor
The price will be very close BUT we are selling the injectors as flow-matched sets which is an added bonus / important!
We will flow them at 400KPa.
Old Aug 16, 2003 | 12:14 AM
XLR8NSS's Avatar
Adkoonerstrator
Hmmmm....I thought I told you to get back to work.
Jack - Is ARE the only sponsor who you deal with on this site or are there others?
Old Aug 16, 2003 | 12:15 AM
Racetronix's Avatar
LS1TECH Sponsor
Look at our web page for dealers.. www.racetronix.com
Thunder is another one.
WORK WORK
Old Aug 16, 2003 | 02:30 AM
Procharged LM7's Avatar
Be glad you are getting them for that killer price. A few of us have bought RC Eng. injectors for like 750 a set, and that is with the 10% discount for being a LS1Tech member. They do drop right in, and plug and play. They are Denso's.
They work really well.
Old Aug 16, 2003 | 04:13 PM
Racetronix's Avatar
LS1TECH Sponsor
These are made by Delphi and they look the same as the factory injector.
http://www.racetronix.com/Injector_17113739.html
