Sound clip with cam inside
Originally Posted by 2003blue5.7
how does it pull? do you have a stall with it?
BTW ... this isn't a NA application.
Before anyone asks ... It's TOG headers coated, stock Y-pipe with gutted cats, into a single in/dual out Flow40 dumped in front of the rear axle. The mic was sitting right in front of the left rear tire just out from under the truck, like if you were standing there.
Originally Posted by Flyer
It pulls like a raped ape ... I've got it shifting at 6500 and the MAF flow still hasn't peaked, which means I could shift it higher if I had the nads to do so. I do want to get some rod bolts and spin the **** out of it. I'll prolly raise it up to about 6700-6900 if I had some rod bolts. It really starts picking up once it gets over 4500rpm.
okI heard the clip sounds very nice.... Do you have a stall in it or are you running the stock verter? I might just put this in my truck I'm running a 5.7 he he
