Some weight reduction
Hey Guys,
While the truck is tore down awaiting the arrival of the PerformaBuilt lvl 2 4L60E, I decided to change a few other things up as well. Extra parts: http://i40.photobucket.com/albums/e2...0528001439.jpg Fuel cell: http://i40.photobucket.com/albums/e2...0528001038.jpg I even adapted the trucks original fuel level sending unit to work inside the cell. Waiting for a transmission, and than to rebuild the dual exhaust. This time without running the drivers bank over to the passenger side. http://i40.photobucket.com/albums/e2...0527001354.jpg I'll also be cleaning up & cutting off extra brackets and pieces not in use under the frame. Cheers ~Mykk |
what is your motor setup?
Originally Posted by 03chevyroyce
(Post 4469842)
Mighty Demon 825cfm double pumper Super Victor copy single plane intake Patriot 'Vortec' iron heads, 185cc Int runners, 63cc chambers 2.02"/1.6" valves Comp XR276HR-10 cam, magnum 1.52 rockers, 26918 beehive springs .040" over 350ci, H345NCP flat top pistons, ZZ4 rotating assembly, balanced 10.7:1 static compression, 8.6:1 dynamic |
The cell is mounted, I've got a question however. The sump has two -8 fittings, obviously one will be used for the fuel feed to the pump. Can I use the other for the fuel pressure regulator return?
http://i40.photobucket.com/albums/e2...0529000802.jpg http://i40.photobucket.com/albums/e2...0529001439.jpg |
Very nice, keep us updated, i plan on puttin a fuel cell in real soon as well. What gallon fuel cell is that?
It's a 20gal cell, wich looks funny to me because it's a 1/3rd the size of the trucks original 26 gal tank.
Lol thats true cuz i wouldnt have figured it was a 20gal
So you have an older vortec 350 in an 2004? Why did you do that instead of the ls engine?
Originally Posted by dlt76028
(Post 4470207)
so you have an older vortec 350 in an 2004? Why did you do that instead of the ls engine?
Originally Posted by 04SilveradoMykk
(Post 4469845)
http://i40.photobucket.com/albums/e2...523001118c.jpg
| All times are GMT -5. The time now is 06:39 AM. |
