Some pics of my home p/p throttle body
Old Dec 4, 2005 | 11:14 PM
  #21
ranwalk's Avatar
Originally Posted by goshawk23
randy, that looks a thousand times better than mine. too bad your whipple fed 6.0 is still slower than my 5.3.
Do you have to keep reminding me of this?
Old Dec 6, 2005 | 12:24 AM
  #22
duwem's Avatar
nice work, nothing like 3 hours of work for .0001hp, but the bling factor is definitely worth 10 at the crank
Old Dec 6, 2005 | 12:37 AM
  #23
looks good great job
Old Dec 7, 2005 | 05:53 PM
  #24
speed01rcr's Avatar
wonder if there is anything else we can do to these things
Old Dec 7, 2005 | 08:26 PM
  #25
goshawk23's Avatar
Truck addict
nah, i just like making myself feel better. we all know the banana owns dirty whitey.
Old Dec 8, 2005 | 03:09 PM
  #26
ZR1 DREAMING's Avatar
That looks great!! What compound are you using and pads?? Can you share your How-to? Thanks.
Old Dec 8, 2005 | 05:00 PM
  #27
SS_bnoon_SS's Avatar
I can't answer what pads or compounds he used, but I run a polishing biz on the side and can answer general questions like this... so...
For the general break down of casting flash, I use 3M 2" surface prep discs, start with rough and finish with ultra fine. In very rare cases of it being rougher than these discs can handle, I start with 2" sanding discs in 200-ish grit.
Once done with the ultra-fine surface prep discs, I go with a rough cut tripoli compound, or a white-rouge as a fist compund step (depending on the material hardness). From there, a red-rouge jewlers compound, then finish with a product called Semi-Chrome (comes in a small tube).
After the polishing is complete, you need to seal the metal surface with either a clear coat powder coating, a metal sealing product like Zoop-Seal, or at least an automotive wax of some kind. This coating will keep the aluminum (or other metal) from oxidizing and ruining your awsome polishing job.
Old Dec 9, 2005 | 10:00 AM
  #28
ok, I can see that... thanks.
But would the "coating" you're talking about breakdown due to engine heat and the constant passing of airflow?? Not to sound like an ***, I really don't know... if not from the air flow, what about a wet shot of nitrous passing through there? If it'll hold up I just may have to bust out the Dremel and get to work!
Old Dec 9, 2005 | 08:51 PM
  #29
Ohhhhh, no, you really wouldn't want to coat the inside for any reason, you'd coat the outside to keep it looking pretty. Sorry for the confusion....
jdb11386
Dec 3, 2015 09:34 PM
Slammed96
Jul 27, 2015 07:22 AM
Ammadien
Jul 22, 2015 08:50 PM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
