So I had Pat G spec me a new cam
Old Apr 11, 2012 | 11:51 AM
  #21
oakley6575's Avatar
WTF. I got screwed. My build was delayed for over a month because I was waiting for the cam. I should have gone directly through Comp instead of what Pat G told me. I guess thats my fault.
Old Apr 11, 2012 | 04:14 PM
  #22
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by AndysC3
hmm, What would you say the shift points should be with that cam? I dont want to shift higher than 6400 once the procharger goes on.
That cam will need to shift higher than that I'd bet money. The gt2-3 I had in my lq4 liked 6300 and your spec'ed cam is 10* larger on both sides. Granted your lsa is a bit narrower which will bring the rpm range down a little.
That cam will perform well with your combo it'll just be shifting higher than 6400. Any reason why you're set of 6400?
Old Apr 11, 2012 | 05:14 PM
  #23
AndysC3's Avatar
Since the procharger builds boost with rpms I dont want to shift too high. So... If I make 11# at 6900 I wouldnt start making boost till about 4K rpm. Or will it be ok? Any procharged guys wanna step in?
Old Apr 12, 2012 | 12:50 PM
  #24
Vortec350ss's Avatar
Andy FWIW I shift my cam at 6350 at the track and its a 222/226 that I had spec'd to run NA boost in mind. Granted I don't know how a procharger changes things as far as shift points compared to NA, but I probably wouldnt go much larger than a 222/230 or so. The other thing is those WCCH heads LOVE lift in the .580 range. Their .600 lift flow is actually less. Again I dont know how that changes with boost, but its something to note.
Old Apr 12, 2012 | 05:02 PM
  #25
ayousef's Avatar
if youre gonna run 11-12psi you will make boost maybe even below 3000rpms.
I ran a vortech on my Z06, and with only 5psi at 7000rpms, I already made positive manifold pressure at 3500rpms.
chvy=power
Aug 31, 2015 10:51 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
NuckenFuts
Jul 9, 2015 08:45 AM
