so hows my cam swap part list looking for my 6.0
Old Jun 14, 2011 | 07:04 PM
BlackGMC's Avatar
Resident Retard
Pac are good. Check out these
http://www.texas-speed.com/p-439-pac...ve-spring.aspx
Old Jun 14, 2011 | 07:22 PM
06sierra5.3's Avatar
I'll probably run 918's when I do mine. there are a bunch out there that will work.
Old Jun 14, 2011 | 07:45 PM
RSTinOKC's Avatar
+1 on dowel rods and its quicker to use the TDC method for changing springs. I highly recommend the LS valve spring tool by procomp.
The head gasket kit was probably recommended because you were planning on changing lifters which would require head removal.
There are cheaper pushrods to be had; I wanna say I picked mine up at SDPC for $90 shipped.
Old Jun 14, 2011 | 11:09 PM
907TBSS's Avatar
How about cam gear? Is new cam single or 3 bolt? This almost put a hamper on my weekend cam swap... I about had a heart attack then raced to dealership.
and x3 on the dowels, a good fail safe and piece of mind. Cut 'em to length and lube em up.
Old Jun 15, 2011 | 03:01 AM
Huntingman2706217's Avatar
Originally Posted by BlackGMC
thanks boss! ill check it out when i get home from work!
ill do some searchin on this also thanks!
i was gonna do the TDC way originally but cam across someone having one of these fitting and it just sounded cool i guess lol... was gonna give it a shot... but saves money not to i guess and if its faster this way then im game...
this im not sure about... i need to find out... i THINK that comp cam cuts all there cams in one or the other... but i have researched to see what i have stock yet... and for sure which comp cams comes with... but my plans are to pull it apart starting a friday and back together for work my monday... so i gotta get EVERYTHING... lol... Its my only ride... lol...
Old Jun 15, 2011 | 07:10 AM
dmelvin's Avatar
You have a 3 bolt cam.
Old Jun 15, 2011 | 07:48 AM
Awesome thanks... Saves me from searching later... Gotta see what pattern this comp cam is... Who sells the different bolt pattern gears?
Old Jun 15, 2011 | 08:05 AM
http://cgi.ebay.com/ebaymotors/LS1-6...item43a61e1b49
Found these pac springs... $165 shipped ain't bad... Just started shopping them though... Down time at work... Only got my phone so hard to do a lot of web site digging...
Old Jun 15, 2011 | 08:19 AM
Any reason why I shouldnt snag these up?
http://cgi.ebay.com/ebaymotors/Comp-...item1e644ce33d
Old Jun 15, 2011 | 11:49 PM
907TBSS's Avatar
Any dealer should have them relatively cheap part.
