so how much lift....
Old Mar 10, 2010 | 08:49 PM
Mr.Nobody's Avatar
Default so how much lift....
how much lift can 706 heads flow with? the tr224 i have is 5.63 but the guy at thunder said i could come in and swap the cam and he will spec me out a new one like a 215/230 with a .629/.592, any ideas? thanks.
Old Mar 10, 2010 | 09:27 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Your going to need to post up more information if you want an answer. Has any work been done to the heads? What size engine? Stock bore?
Old Mar 10, 2010 | 09:42 PM
Mr.Nobody's Avatar
5.3 going to have shaved and ported heads, shaved .35 patriot extreme springs, stock bore, thanks
Old Mar 10, 2010 | 09:56 PM
1FastBrick's Avatar
well a stock 706 head will flow near the 220 range on the intake side in the upper .500 inches of lift. but each flow bench will read a little different. after .500 they really dont gain much in stock forum. may be a few cfm but if you just clean the bowl area up properly you can gain nearly 40 cfm. you dont start to see the difference untill around .300.
The best thing to do would be to have the heads ported first and then flowed to get the best cam for your application.
Old Mar 10, 2010 | 10:16 PM
Mr.Nobody's Avatar
ight thanks, they told me and 30 or more cfm, so idk thanks for the input though
Stroked385
Jan 22, 2013 07:06 PM
OrangeChevyII
Dec 10, 2011 07:34 PM
'02SOMz28
Aug 15, 2010 07:44 PM
silver-mod-o
Sep 5, 2007 03:17 PM
