So heres the plan
Old Mar 20, 2016 | 08:31 PM
X_Racing1's Avatar
it a brian tooley racing cam and i said i was going with the fti 3200 converter
Old Mar 20, 2016 | 08:32 PM
X_Racing1's Avatar
but wolf your prolly right
Old Mar 22, 2016 | 12:32 PM
gagliano7's Avatar
That cam is huge for a camaro which weighs a lot less than your truck. In a big heavy truck like yours it will be a dog. I would have Kip from cam motion or Martin from Smallwood racing spec you a cam for your setup. And you have a 5.3. I don't even think that cam would have enough ptv clearance.
Old Mar 22, 2016 | 04:35 PM
X_Racing1's Avatar
Thanks Gagliano7. I have another question. I'm thinking of getting a core short block 6.0L now someone told me that if you put 5.3L heads on a 6.0L it moves the comp ratio to like 11.0 to 1 is this even close and will the 5.3L heads work on a 6.0L?
Old Mar 22, 2016 | 08:00 PM
Blwn99x's Avatar
Btr stage 3 truck cam 218/224 552/552. I picked up 51 hp already having long tubes,ypipe, and cat back with this cam. Pulls to 6000 easy, I shift at 6200
Old Mar 22, 2016 | 08:33 PM
Wolftrk99's Avatar
The 5.3 heads will work and it will bump the compression up, because the combustion chambers are smaller..... But you may want to look into some bigger valves in the 5.3 heads too....
Old Mar 22, 2016 | 11:51 PM
X_Racing1's Avatar
how about this?
DUR @ .004" 278*/ 286*
DUR @ .050" 216*/ 224*
LIFT .551/.551
LSA 115*
5A
Old Mar 23, 2016 | 12:47 AM
Wolftrk99's Avatar
Think youd want little less lsa 113/112 somewhere
Old Mar 23, 2016 | 12:57 AM
X_Racing1's Avatar
when btr has that same profile on a 1
Old Mar 23, 2016 | 01:01 AM
X_Racing1's Avatar
btr has that same profile on a 113+3 does the +3 mean 116? and im going to spray this engine up to 200 hp do you think 113 is enough? thats why i thought 115
