Smoke Problem
Old Feb 4, 2009 | 03:28 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Exclamation Smoke Problem
Well I started the truck up today, let it idle for a bit than noticed that my truck was burning oil I checked for leaks and everything seems to be fine but my oil level is a bit low. I forgot to add that I found a little bit of oil in the tips and tailgate. What do you guys think would cause this? Thanks
Old Feb 4, 2009 | 03:32 PM
LoweredZ71's Avatar
Only two ways for oil to get in the exhaust thats valve guides and seals or past the rings,or pcv . Sometimes a plugged pcv will cause it
Old Feb 4, 2009 | 05:04 PM
Low_LSX's Avatar
It's at the shop now getting checked but I would still like some advice I think a 370CI might be in the works if I can get a good deal on pistons and rods. any one have a good place to get them also what gaskets do you guys recommend? I'm looking for 10.1 Comp ration with LS6 heads.
Old Feb 5, 2009 | 07:14 PM
Low_LSX's Avatar
Looks like I need a new oil pump and adding a catch can for safety with LS2 timing chain.
Old Feb 6, 2009 | 11:32 AM
thunder550's Avatar
High on diesel fumes
Curios how a bad oil pump causes oil out the tailpipe...doesn't sound right to me.
Old Feb 6, 2009 | 12:00 PM
Low_LSX's Avatar
It was the PCV but I needed to change the oil pump since I never did.
Old Feb 6, 2009 | 01:39 PM
thunder550's Avatar
Ahhh I see.
Old Feb 6, 2009 | 02:26 PM
Low_LSX's Avatar
Ahhh I see.
Wana help with the install of everything?
Old Feb 6, 2009 | 11:51 PM
thunder550's Avatar
Well ****, I just did mine about a month and a half ago, so it's fresh. When were you thinking?
Old Feb 7, 2009 | 02:31 AM
Low_LSX's Avatar
Whenever your free.
