SLP "ZL402" LS1 and LS2 short block assemblies on sale!
Old Oct 19, 2005 | 10:08 AM
tbyrne's Avatar
Default SLP "ZL402" LS1 and LS2 short block assemblies on sale!
We have a sale that covers all of the SLP ZL402 short blocks. High and low compression versions are available for the LS1 and LS2 assemblies -
The ZL402 LS1 based iron stroker short block is loaded with the kind of top-quality hardware found in short blocks costing much more. It was the first choice for the experts at Car Craft magazine, who took an off-the-shelf ZL402 stroker motor and produced over 575 horsepower, naturally aspirated.
Our ZL402 is built around a new GM LQ9 Gen III 6.0 liter block, a 4.00" forged steel crank, and 4.00" forged aluminum pistons.
This package is sold only in short-block form, minus manifolds, camshaft, oil pump, and other equipment. The advantage of this approach is it allows you to pick a combination best for you.
Although designed primarily for use in late-model F-Bodies and Corvettes, the ZL402 also makes a great choice for street rods, muscle cars, and trucks. Best of all, it's sold outright, eliminating the shipping hassles and expenses of core returns.
You won't find a higher-quality, better value LS1 stroker motor anywhere!
LS1 High Compression Features -
Built entirely from brand-new parts.
Sold outright, no cores required!
GM LQ9 iron 6.0 liter block (includes block plugs)
4.000" Eagle 4340 forged steel crankshaft, balanced to rotating assembly
4.000" Ross 2618 forged alloy pistons with -6.00cc dish (includes new rings and full-float pins)
402-CID displacement
Eagle 6.125" H-beam rods
Includes new, factory-installed cam bearings; Clevite rod and main bearings
11.3:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
Designed for naturally aspirated applications
Capable of supporting up to 600hp
Meticulously assembled to OEM tolerances and specifications.
Oil pump, timing chain, camshaft, pans, plates, and covers not included.
ZL402 OEM-quality fender badges (pair).
LS1 Low Compression Features -
4.000" Ross 2618 forged alloy pistons with -28.50cc dish (includes new rings and full-float pins)
9:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
Capable of supporting up to 700hp
NOTE: SLP STRONGLY recommends that final assembly and installation be performed by an experienced, professional mechanic. Assembly/installation instructions are neither included nor available with this part.
The regular price for each of the LS1 short block assemblies is $3549.99. We are able to offer each of them for only $3299.99 through October 31st!
12400 Crate-Engine Assembly, ZL402" LS1 Short Block (High Compression)
12401 Crate-Engine Assembly, "ZL402" LS1 Short Block (Low Compression)
The ZL402 LS2-based aluminum short block builds on the success of SLP's original ZL402 iron short block. This new package uses the same race- proven internals as its iron block predecessor but features the all- new LS2 block for weight savings of over 100 pounds compared to an LQ4/LQ9-based engine.
Although designed primarily for use in late-model F-Bodies and Corvettes, the aluminum ZL402 also makes a great choice for most late-model GTOs, street rods, muscle cars, and trucks. Best of all, it's sold outright, without core charges.
LS2 High Compression Features -
402 CID displacement
GM LS2 aluminum 6.0-liter block (includes block plugs)
11:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
6.125" Eagle H-beam rods
Includes new, factory-installed cam, rod and main bearings.
Comes with everything required to retrofit into an LS1-equipped car or truck
Assembled to OEM tolerances and specifications.
Capable of supporting over 600 hp.
Oil pump, camshaft, pans, and plates not included.
ZL402 badges (pair).
LS2 Low Compression Features -
Capable of supporting over 700 hp.
The regular price for each of the LS2 short block assemblies is $3949.99. We are able to offer each of them for only $3699.99 through October 31st!
12412 Crate-Engine Assembly, "ZL402" LS2 Aluminum Short Block (High Compression)
12413 Crate-Engine Assembly, "ZL402" LS2 Aluminum Short Block (Low Compression)
*These items must be prepaid with a certified check or money order. Please contact us to receive a shipping quote to your location.
Old Oct 19, 2005 | 01:44 PM
14 Second Truck Club
How much shipping to Chicago, 60638?
Email- mzoomora@msn.com or PM please.
Old Oct 19, 2005 | 01:57 PM
tbyrne's Avatar
Shipping has been in the $240. - $280. range. I'll see about getting an exact quote for you.
Old Oct 19, 2005 | 02:13 PM
tbyrne's Avatar
Shipping would be $285. There is also a $100. crate charge.
noproblems209
Aug 10, 2015 06:57 PM
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
steves86ta
Jul 28, 2015 10:21 AM
Gadgetized
Jul 22, 2015 11:55 AM
