SLP 1.85 rocker arm GP
Old Feb 28, 2003 | 01:00 PM
tbyrne's Avatar
Default SLP 1.85 rocker arm GP
We are running a GP for the SLP 1.85 rocker arm packages. They are designed for gen III engines (LS1, LS6, Truck 4.8,5.3,6.0). SLP's exclusive design is based on the stock rocker and is built by the OEM manufacturer using the same high quality materials and processes. Versus the stock 1.7:1 ratio rocker, SLP's 1.85:1 ratio rocker will result in horsepower and torque gains by increasing lift by approximately 10% and forcing the valves to accelerate faster during opening and closing. SLP's rocker was designed as a bolt-on replacement for stock. No valve cover or cylinder head modifications are necessary and stock pushrods can be re-used. Depending on model application, optional SLP valve springs may be required. The rockers are offered in 4 kits to suit your particular needs. Refer to the application chart for details. SLP highly recommends our tool set (PN 53306) for proper installation. Refer to SLP's application chart (stock camshafts only) to select the kit you need.
5 or more orders are required by March 14th for the following prices -
53300
SLP Rocker arm package
$384.99 with shipping
53302
Rocker Arm Package, LS1/LS6 w/LS6 Springs, Keepers
$519.99 with shipping
53304
SLP Rocker Arm Package, LS1/LS6 w/SLP Springs, Titanium Retainers, Keepers
$719.99 with shipping.
53306
SLP Valve spring compressor with air hold fittings
$49.99
Orders can be placed on our website or by calling 1-877-4-TBYRNE.
Tom
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
vipergtrdj
Sep 16, 2015 07:06 PM
chvy=power
Sep 8, 2015 11:06 AM
