Single Turbo
Old Aug 12, 2002 | 06:32 PM
99GMC Can's Avatar
Default Single Turbo
Hi there, new to the site, just checking in.
I have a reg cab step side 5.3 4L60E
Mods: Transgo kit (very firm)
DJM 2-4 lower
255/50/16's on stock rims
Plan: Electric fan in front of rad
Single turbo in front of pulleys
(just enough room)
Duramax intercooler
The turbo I have was pushing 15psi on a 5.7
I figure if I can set the wastegate to 5psi for starters and play from there.
The trouble is the PCM is stock. Since lean is mean. I don't want to melt anything. I'm looking for someone within a day or two that has LS1 edit (or something) 500 USD gets close to 800 CAN$ by the time I get it. That seems like a lot of money for some software and a patch cord. If I'm not mistaken, all the program does is change a few parameters in a register. I'm surprised there are no pirate or "amatuer" setups out there. If I wait, I'm sure GM will issue something.
Its strange to wait for something you need to go faster
Old Aug 12, 2002 | 07:10 PM
GMC SKI's Avatar
Default Re: Single Turbo
where are you located if your interested I'm planning on buyin edit for my truck maybe split the costs
Jim
Old Aug 12, 2002 | 07:13 PM
GMC SKI's Avatar
damn your in BC ..
Old Aug 13, 2002 | 01:29 AM
Phatchevy's Avatar
welcome to the site.
i was just wondering about your tires. right now i am running a 275/65/16 on stock rims. i also have a 2/4 drop but i was wanting to go with a lower profile tire, but not look stupid because of the stock rims. is yours pretty low? any traction problems? if you have any pictures i would like to see them. if not oh well....
Old Aug 13, 2002 | 04:22 AM
SD-Silverado's Avatar
I had 255/50/16s tires on my ride. With that profile I had traction problems. Not much rubber to work with.
Here's a pic.
http://members.***.net/clevorguy/silverado1.jpg
The drop is a 3/4 from Belltech.
Old Aug 13, 2002 | 05:53 AM
red53gmc's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SD-Silverado:
<strong>I had 255/50/16s tires on my ride. With that profile I had traction problems. Not much rubber to work with.
Here's a pic.
The drop is a 3/4 from Belltech.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I hope you weren't driving around for too long without the lug covers. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
<small>[ August 13, 2002, 03:39 PM: Message edited by: red53gmc ]</small>
Old Aug 13, 2002 | 10:05 AM
99GMC Can's Avatar
Traction is good when I run 28psi. Remember engine is stock and 3.42 gears. At 35psi, the rated preasure, it's easy to spin. Much better for sliding in the corners <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 13, 2002 | 02:24 PM
AKZ71's Avatar
I just had a set of Toyo's put on the truck. They are 275/60/16's on the stock rims. At first I was not very pleased with the look with my truck being 4wd and all but it has grown on me a bit. They Toyo's have awsome traction on both wet and dry roads. You should be fine if you have a 2wd truck that has been dropped.
Old Aug 13, 2002 | 07:14 PM
OVER TORQUED's Avatar
Hi another neuby here. 99GMC you'll well probable have to use a Duramax radiator too. The Duramax radiator bolts to the intercooler then bolts to the normal radiator mounts. Also if your truck has a engine oil cooler you will have to mount another cooler up front. Diesel engines generally have oil cooler built in to the engine its self. I knew that idea was too simple to be the only one to think of it. I trying to do the same with my 8.1L but Im currently on the hunt for a turbo that will work for me. Hopefully I can find one off of a production diesel engine they usually are cheaper.
Old Aug 13, 2002 | 07:27 PM
CHAGO's Avatar
nice looking ride canadian...
reminds me of my old baby <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" />
