Silverado SS or 2500?
Old Oct 7, 2004 | 09:37 PM
GEAR M UP's Avatar
Truck rides great.......
Old Oct 7, 2004 | 09:51 PM
moregrip's Avatar
what a rush!
Sorry, I was asking Quicktime if ride quality was a criteria for him?
Old Oct 7, 2004 | 11:01 PM
BigTex's Avatar
The SS may not be a tire fryer in stock form, but it doesn't take much to wake it up. I'm more than pleased with mine. I tow a small trailer some with no problems. The all wheel drive setup is great in poor weather conditions. I'm amazed at how sure footed it is.
Old Oct 8, 2004 | 09:30 AM
Quick Time's Avatar
I am going to test drive both, but im not picky on the ride quality. I just dont want to be driving an International.
Old Oct 8, 2004 | 09:33 AM
ACDenali's Avatar
Id opt for the SS unless you tow very heavy loads. I pull fbodies all the time with my Denali and it does awesome. Quadrasteer helps too
Old Oct 8, 2004 | 09:44 AM
marc_w's Avatar
I tow a max of about 5,000lbs with my SS. It's a older 24' travel trailer. It handles it well.
I'll never have enough power, but it's like any gasoline engine pulling on the highway.... downshifting out of OD/Lockup on hills, having a bit of a hard time holding 70mph up smaller hills in a headwind. (the huge brick shape of the trailer probably doesn't help)
Around town and at slower highway speeds, it's excellent. I'd have no problem pulling our trailer across the country right now.
One thing to note, I *NEEDED* to get a weight distributing hitch for the trailer. If you're pulling cars, where you can adjust the tongue weight, this might not be needed for you. With the travel trailer, I'm limited on how I can adjust TW.
Supposedly the SS uses the Z71 suspension, minus the 2" lift blocks above the axle. My old Avalanche, with it's butt way up in the air, handled the tongue-weight perfectly. The SS popped a wheelie. (front wheel wells higher off the ground than the rear). If it was a regular Z71 truck (with those lift blocks), the thing would have leveled out perfectly.
I have a Reese 800lb setup, and it works awesome.
Old Oct 8, 2004 | 09:51 AM
2bseen's Avatar
11 Second Truck Club
I tow a 21' scarab and 16' enclosed motorcycle trailer with mine and it does good.
Old Oct 8, 2004 | 09:54 AM
Quick Time's Avatar
This is great info guys. After i pick one up im going to be looking a tri y header to make for it to increase torque. I can leave anything stock
Old Oct 8, 2004 | 10:15 AM
Radix
Old Oct 8, 2004 | 10:19 AM
SSLink's Avatar
I kinda just went through the same process. I was thinking about a 2500HD with the 6.0 or even the 8.1 BBC. Then I found a good year-end deal on a 2004 SSS and went for it. I am real happy with the truck and the LQ9 under the hood which evidence shows can gain another 30 HP just from tuning and maybe an aftermarket airbox or filter.
Mine will be getting some serious "intake" work soon in the form of a Radix.
