Siemens/Mototron Shorty 60 lb./hr injectors
Old Mar 2, 2006 | 07:11 PM
OBXMarine's Avatar
Default Siemens/Mototron Shorty 60 lb./hr injectors
These are plug and play (mechanically) right?
http://www.harrisspeedworks.com/shop...cat=331&page=2
Old Mar 2, 2006 | 07:20 PM
CHarris's Avatar
Nope... those in the picture have a "car" style plug. The height of the injectors loosk about right... but the plug is not a "truck" plug. Woudl still require a injector pigtail conversion.
Old Mar 2, 2006 | 07:45 PM
quicksilverado's Avatar
You will need spacers also. They are shorter than the truck injectors.
Old Mar 3, 2006 | 12:50 AM
OBXMarine's Avatar
Hmm, OK...along the lines of Yelo's post, what injectors require no modifications and have a greater rate of flow than stockers. I'm looking for 42-60lb injectors.
As always, thanks!
Old Mar 3, 2006 | 08:05 AM
The 43 lb injector that are not the stubbies are direct replacement.
Old Mar 4, 2006 | 05:27 AM
OBXMarine's Avatar
These ones then right?
http://www.harrisspeedworks.com/shop...cat=331&page=1
What's all involved with the spacers? Is it just simple tube spacers to support the injectors? I've been reading up on this subject a good bit lately, but can't seem to dig up the information I remember when I was looking into this a year or so back.
Old Mar 4, 2006 | 04:32 PM
greentahoe's Avatar
Are all mototron 60lb/ hr high impedance injectors the same? Or are there different connectors or applications??
There is one that states "shorty" and the other does not. Are they the same? Will either style work for us??
Old Mar 4, 2006 | 06:32 PM
XLR8NSS's Avatar
Adkoonerstrator
We need a Multec II type injector. The car styles are Bosch style injectors. I'm not sure what the Mototron are but, they're not Multec II's.
If you want to go to injectors bigger than 44lbs/hr(rated at 4bar) it's best to go straight to a bosch style(car) injector. The Mototrons are shorter than the truck injectors if I remember right which might make swapping them in harder than using the bosch style injector. The Bosch style is the best way as there are LOTS of options out there for injector size.
Here is the injector conversion write up I did a while back.
http://hauln.net/LS1Tech/truck/fuel_injector/
flatblack83
Jan 3, 2026 07:10 PM
FlyingLow
Nov 24, 2015 10:05 AM
OHsixLS3
Sep 25, 2015 11:20 AM
jroctpb
Sep 16, 2015 09:05 PM
Cowboy Tom
11
Sep 16, 2015 09:35 AM
