Shimming a converter??
Old Nov 17, 2003 | 10:40 PM
Black Blown 02's Avatar
Default Shimming a converter??
I've had 2 yanks in my truck, my trans installer had to shim my TT3000 with 2 washers, and my SS3800 with 3 washers. Is this common with all converters, or just Yanks?
Anyone else had to shim theirs?
Old Nov 17, 2003 | 10:58 PM
ranwalk's Avatar
Did not have to shim mine.Yank TT 3000
Old Nov 17, 2003 | 11:02 PM
O3GMC's Avatar
12 Second Club
I dont think the tranny shop shimmed mine - I asked him and he acted like he had never heard of doing that
Old Nov 17, 2003 | 11:04 PM
parish8's Avatar
single digit dreamer
huh? i hope to be puting mine in tomorrow, anyone care to tell me more about this shiming?
Old Nov 17, 2003 | 11:18 PM
From what I understand, you shim it with washers in between the mounting lugs on the converter, and the flexplate. You look for a clearance the thickness of a nickel. (this is what I'm not quite clear on) I think the clearance is the amount of converter engagement into the pump?? Too much or too little and my trans guys say it will take out the pump.
This is from the most reputable trans place around here(not some quickie trans place) The 2 guys that own the place have been in business for 25 years only doing transmissions and are old school hot rodders. So I hope I can trust them.
Old Nov 17, 2003 | 11:19 PM
Hopefully someone can clear up what I'm talking about!
Old Nov 17, 2003 | 11:29 PM
Hit Man X's Avatar
Alls I know about the pump engagement is that it needs to be fully seated. I have never heard of this shimming...but I learn stuff all the time.
Old Nov 17, 2003 | 11:33 PM
Yeah, seems like they said if its not fully seated when bolted to the flexplate, then is when you shim.
Old Nov 17, 2003 | 11:42 PM
Hit Man X's Avatar
Like the snub that goes into the pump is too short? If so that does make some sense but I'd assume as long at it is fully seated on the pump it should be okay
Old Nov 17, 2003 | 11:45 PM
You guys know a trans expert on this board that can chime in on this?
