shift time info needed
Old Jan 30, 2004 | 08:03 AM
bigguy75inches's Avatar
Default shift time info needed
can someone post a picture of what ls1 edit on teh desired shift time table should look like. I have a stock tranny, and just want improved shifts.
Old Jan 30, 2004 | 10:03 AM
Flyer's Avatar
I have heard that making them 0 can be harsh, I've also heard just the opposite. From my experience they didn't have much effeft on the way it shifted one way or another. The RADIX tune moved them to .2 all the way across. That's what I will do with mine...
If you want better shift, multiply the Trans Calibration > A4 Shift Firmness > Positive pressure vs Temp table by about 80%.
Then do the Base pressure vs TRQ table. Add 5 to that one all the way across. After that you will need to raise the Maximum Line Pressure up to 95.
Old Jan 30, 2004 | 11:01 AM
Texas Terminator's Avatar
11 Second Club
do what flyer said, that sould help a bit. i would not recommend zeroing out your shift time table, i have been told that it can cause your shifts to overlap thus damaging your tranny. i have personally played with them and seen no significant difference anyway.
Old Jan 30, 2004 | 12:04 PM
Old Jan 30, 2004 | 04:42 PM
mine are all set at .400 and it seems slow shifting
Old Jan 30, 2004 | 05:37 PM
Flyer's Avatar
That's cause it is ... the stock internals make it do that. Get ya a shift kit ... and that will help.
Raising the line pressure should help a little too. Have you given that a try yet?
Old Jan 30, 2004 | 10:36 PM
no, im scared to break something,,,, you know what they say, if it aint broke, dont fix it.
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
lxcoupe
Jul 14, 2015 10:14 PM
Aboss
Jul 9, 2015 10:28 AM
