SES light and TPS reset ????
Old Sep 16, 2004 | 09:58 PM
vanillagorilla's Avatar
Default SES light and TPS reset ????
About a week ago my SES light popped on...again. It did this before with a previous tune, and now it did it again. Its the TPS code "P0121". With the first tune for my after my cam swap, the track ran ok. I had to crack the throttle blade to get it to idle. Then the it threw the SES light, and it ran like crap.
Allen sent me a new tune, and before I put it in, I reset the throttle blade back to stock. It ran like a bat outta hell! Then about a week ago the code was thrown again. It runs like crap!
I've tried turning the key on with the TPS unplugged to reset it, and I've disconnected the battery for like 8 hours. Nothing will clear the SES light, and it still runs bad. I know I could just delete the code, but it's just going to come back. HELP ME PLEASE!!!
Old Sep 17, 2004 | 06:21 AM
2001si3rr@'s Avatar
I had the same problem with my 01 GMC. If you put it back stock give it some time to learn it again before you try adjusting the blade anymore.
Old Sep 17, 2004 | 12:16 PM
I have like almost 300miles of relearn time on this tune....and with the throttle blade back to the stock setting.
Old Sep 18, 2004 | 12:17 PM
Does anyone have any idea how to reset the throttle body?
Old Sep 18, 2004 | 09:09 PM
Try resetting the PCM by pulling the fuses (2 fuses ECM BAT and ECM something else). You can do a search to find the right fuses.
Then try doing an idle relearn - start engine, set park brake, put in drive, idle 5 min in gear, then put in park and idle 5 more min.
RustyD
May 23, 2016 07:04 PM
Avalanche2002
Nov 30, 2015 07:31 AM
legerwn
56
Nov 15, 2015 10:21 PM
carid
Oct 1, 2015 09:22 AM
the owl
Sep 4, 2015 04:09 PM
