SES light, right bank lean code
Old Dec 1, 2006 | 04:51 PM
jimmyp's Avatar
Default SES light, right bank lean code
99 silverado with a 5.3 and 80k miles. Just bought the truck and it threw a SES light. Ran the code and it said the right bank was lean or something like that. Ive heard this can be a fuel filter or maybe o2 sensors. I will be replacing the filter but I dont want to replace all the o2s unless I have to. Is there any way to test them to see if they are the problem?
Old Dec 1, 2006 | 05:20 PM
Grumpy5.3's Avatar
replace the bank 2 sensor 2 o2 sensor.... post cat pass side...
Old Dec 1, 2006 | 05:25 PM
jimmyp's Avatar
how do you know that?
Old Dec 1, 2006 | 06:39 PM
RyanA's Avatar
What was the code number?
Old Dec 1, 2006 | 06:47 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Could swap the left with the right... if code follows, badda bing, badda boom! If not, look at the front sensor. Can't say for sure without knowing the P-code?
Old Dec 1, 2006 | 06:49 PM
jimmyp's Avatar
I didnt scan it myself...I knew I should have gotten the code! Knowing the exact code would tell me what sensor it is?
Old Dec 2, 2006 | 04:25 PM
Doobie's Avatar
Default Possible CC problem
I had the same problem myself. Bank 2 sensor 2 showed lean condition.
Front o2 sensor monitors engine and rear o2 monitors cat performance. I too suspected a bad o2 sensor so I took it to a friends garage and he pointed an infrared temp gun at it and it showed a difference of 100* cat discharge temperature behind bank 2 as compared to bank 1. He said the cat. wasn't working properly. I contacted Dynatech and after explaining the problem they did (reluctantly) send me a replacement cat at no charge. Problem solved.
Old Dec 2, 2006 | 04:40 PM
1SlowHoe's Avatar
Destroyer of Transmissions
It seems most people always want to replace a sensor. There's a very good chance the sensor is fine and doing what it was designed to do...tell you your cat is malfunctioning. Swap the passenger side with drivers side O2 and see if you get the same code. If you do, the sensor is telling you what is wrong.
Old Dec 2, 2006 | 06:21 PM
Grumpy5.3's Avatar
b/c my truck was doing the same thing, replaced intake gaskets, and there is a buletin about it.... the o2 sensor causing the problem
Old Dec 2, 2006 | 07:41 PM
95ImpSS's Avatar
...which is why knowing the trouble code is important. Not knowing the code, I suggested swapping the sensor. If problem followed, then you have the issue. If not, then problem lies in the emissions.
Always post the codes. Makes helping easier.
