SES light is on
Old Jul 17, 2002 | 11:46 AM
Default SES light is on
I had the change oil light come on, and I changed the oil, but never reset the light. now when i turn the truck on and start it, the change oil light doesnt come on but the ses light is lit. is it from not reseting the oil light. how do i clear the ses light. I dont have a GM smart tech tool handy.
Old Jul 17, 2002 | 11:57 AM
RED2K's Avatar
Default Re: SES light is on
I KNOW THIS SOUNDS CRAZY BUT TRY IT. TURN THE KEY ON AND COMPLETELY PUSH DOWN THE GAS PEDAL 5 TIMES VERY QUICKLY, CHEVY SAID LIKE IN A 2 SECOND TIME FRAME AND THEN START THE MOTOR . IF THAT DOESNT DO IT DO THE SAME BUT TURN THE KEY OFF INSTEAD OF STARTING IT. THATS HOW I TURN MY OIL CHANGE LIGHT OFF.
Old Jul 18, 2002 | 02:27 AM
99Silver6.0's Avatar
Do you have AutoTap or know someone that has it. See if you have any active DTC's, that might be the reason your SES light is on.
Old Jul 18, 2002 | 05:41 PM
Phatchevy's Avatar
unhook your positive battery cable for like 10 minutes. then hook it all back up. it should be fine if it is still lit up than something might be wrong. as for the oil change light. you should do what RED2K said. accept that you don't have to do it in a 2 second time frame. just keep pushing the pedal till that oil change light turns off. (should be 5 times) hope that helps..
RustyD
May 23, 2016 07:04 PM
dantheman1540
Feb 24, 2016 09:56 PM
Avalanche2002
Nov 30, 2015 07:31 AM
legerwn
56
Nov 15, 2015 10:21 PM
carid
Oct 1, 2015 09:22 AM
