SES Help
Old Jul 8, 2004 | 03:45 PM
WaitinToDrag's Avatar
Default SES Help
After I finished doin a few things today, my SES light is on. heres what I did and maybe someone can give me an idea....
*uninstalled nitrous wiring...only 2 of the red wires were hooked up to other wires underneath the dash
*unpluged MASairflow sensor...but forgot to disconnect battery
*modified the K&N heat sheild to fit the radix intake tube. i thought i coverd the MAS pretty well while i was grinding the edges down
*had to reconnect one of the butt connectors on the TB
*replace guage cluster fuse..shorted it out while unplugging n20
took it for a drive....seems fine
any thoughts?
Old Jul 8, 2004 | 08:17 PM
ok...no i have no 1st or 4th GEAR!!!!!! WTF!?!?
Old Jul 8, 2004 | 10:00 PM
HAZE's Avatar
sounds like you did more than blow that one fuse. check all your fuses and wiring nest to the the wire that blew the fuse. you may have had a power surge to the pcm somehow, does everything else work ? i'm guessing you don't have any way to scan or reset ses ? try disconnecting power for awhile and reconnect, force the pcm to reboot. no idea why you would lose two gears. e
Avalanche2002
Nov 30, 2015 07:31 AM
legerwn
56
Nov 15, 2015 10:21 PM
JCW
Sep 22, 2015 03:59 PM
rojeho
Aug 8, 2015 07:20 PM
Flem
Aug 2, 2004 12:54 PM
